Author Topic: **HELP**Tapping coming from drivers wheel at low speeds  (Read 1229 times)
Offline brosnan
Any help/advice will be great here:
I started getting a tapping noise from front end, took to local garage and they said cv joint...
Okay replaced it !!!! The noise continued, so took it back to them and the said i had actually shreaded the off side driveshaft teeth etc but, Cause they made me replace part which didnt need doing nor stop the prob they took it back and did all that. Noise faint but still there!!!
I have been told i need to replace the suspension top mounts cause my coilovers have nackered them.
I thinking wheel bearing.....??????
Thanks
Offline Steve_PD
Re: **HELP**Tapping coming from drivers wheel at low speeds
« Reply #1 on: 17 June 2010, 20:26 »
wont be wheel bearing, it makes a sort of grumbling noise which gets louder with speed.
did you change the top mounts when the coilovers where fitted?
Offline Lewisf1988-DUB
  • 1.8T AGU
« Reply #2 on: 17 June 2010, 20:31 »
ARB tapping ever so slightly on drive shaft as ur driving over little bumps nd stuff?
Offline brosnan
« Reply #3 on: 18 June 2010, 14:09 »
I got no arb at min!!!! Just bought eibach one but awaiting fittment until this noise gone!!
I didnt change top mounts na, the garage that did all the above work said that the top mounts were gone.
It defo sounds as if a bearing is smashed and trying to move... weird metal tapping..
Thanks for advice  :smiley:
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #4 on: 18 June 2010, 14:37 »
have you checked your front wishbone rear bushes to make sure they havent started splitting.
if they haveyou will notice vibration in the wheel when going forwards or backwards.
Also could be strut top bearing, that has been over tightened n crushed when fitting coilovers
