Author Topic: mk3 cold start problem  (Read 1346 times)
Offline doghair
  • mk3 gti 8v
« on: 20 December 2004, 17:09 »
hi
when i start the car from cold it starts but dies straight away (but ok when keep foot on it) it stabilizes its self after a minuet and is fine.
i can hear the valve trying to open (tapping)
and it still taps even after its warm.
i think its something to do with the throttle valve potentiometer its simos management system, 97, agg engine code
ive also just changed the battery
any ideas thanks
join the new fantasy league starts soon in chat tread
Offline Saqib
Re: mk3 cold start problem
« Reply #1 on: 28 December 2004, 14:55 »
I had this problem on one of older golfs a commmon fault with these is the transmission coil. Its the box you plug the coil lead into.
To be honest it could be alot of things.
Have you checked the spark plugs
Offline Saqib
« Reply #2 on: 28 December 2004, 14:59 »
Another thing it could be is metal thing above and to the rear of where the spark plugs are.
I think its called the idle switch or meter i cant remember now. It could also be your battery on its way out.
Offline nobbin
« Reply #3 on: 31 January 2005, 21:39 »
hi,could be loads of probs...check spark plugs...someat up with fuel injection sysstem....ignition system[coil etc]..low cylinder compressions
