Author Topic: New Interior  (Read 1980 times)
Offline kevo
New Interior
« on: 20 December 2004, 09:46 »
I received my new brushed alu dash last week and i managed to get most of the parts fitted but i need some advice in getting the lid of the astray off, the passanger side door handle off and how is the front of the cup holder attached to the cassette. :undecided:
Thanks,
Kev
Offline topher
  • Administrator
  • fully functioning
Re: New Interior
« Reply #1 on: 20 December 2004, 10:07 »
Ash tray - Slide the lid back, pull the liner out, you'll see a small screw in the bottom. Take the screw out, and rock the tray off the carrier and pull the whole thing out (this is where you have to unplug the cigar lighter) Seperating the lid is a bit of a c*nt but its on sliding clips, you'll get it eventually.
Passenger door pull - _Carefully_ prise the trim insert out of the middle to reveal the holding screws.
Cup holder - This one can be tricky, first off.. make sure you have the revision B cupholder, or your new trim wont fit at all. Difficult to describe the difference between the two, but basically a rev. B holder will eject all the way out when you push the top in, a rev. A holder needs to be pulled out.  You can get the rev. B cassette from the dealership for about 30 bar.
If you already have the rev. B cassette, then you will see two silver clips, one at each end, the trim snaps out and slides off these clips, fitting is the reverse.. slide on and snap in.
Hope that helps, and you just reminded me I still haven't fitted my door triggers yet :undecided:
Offline kevo
Re: New Interior
« Reply #2 on: 20 December 2004, 11:40 »
 :grin:
Nice one Topher,
I now have something to do this evening. I have the Rev B Cup holder so thats a start.
Thanks again,
Kev
Offline topher
  • Administrator
  • fully functioning
Re: New Interior
« Reply #3 on: 20 December 2004, 11:45 »
having second thoughts about the passenger door pull now.. it definitely seperates but cant remember at which point, i'll find the old one out when i get home and have a look if i remember.
Offline kevo
Re: New Interior
« Reply #4 on: 23 December 2004, 11:03 »
I have managed to get the ash try out and the lid off, But the lid is in two parts and i am having trouble removing the slider from the wood effect cover. Regarding the passenger door handle, The trim insert does not come off. Any more suggestions. This is beginning to wreck my head. :angry:
Kev
Offline topher
  • Administrator
  • fully functioning
Re: New Interior
« Reply #5 on: 23 December 2004, 11:25 »
Definitely seperates in some way .. find a join line and stick a screwdriver in to pull it apart ... i remember i left a few marks on my old one when i removed it.
edit: just been out to have a look, the whole face of the door pull comes away from its base, and its a tight fit.
« Last Edit: 23 December 2004, 11:28 by topher »
