Author Topic: Mk V, 05 plate, Engine idle problem !  (Read 11590 times)
Offline Saint Steve
Re: Mk V, 05 plate, Engine idle problem !
« Reply #20 on: 14 June 2010, 19:05 »
i dont know of any, but Hurdy may know of where to direct you. I havent a scooby. If youve removed your Airbox, its only 4 bolts and  2 small hoses, and its off. It bolted to the side of the rocker box. Really easy. Airbox removal is just as straight foward, but be gentle with it when pulling it off the top of the engine.
He'll most proberly recommend the BSH fix kit.
Offline winrya
« Reply #21 on: 14 June 2010, 19:08 »
Cheers mate, I prefer the oem solutions.  Do you not need to remove the engine cover?  Also did you replace the breather pipes and the orange rubber gasket?
Cheers,
Ryan
Offline Saint Steve
« Reply #22 on: 14 June 2010, 22:33 »
No just the Pcv housing where the diaphragm sits inside. Orange o rings where fine
Offline jaydubveedub
« Reply #23 on: 15 June 2010, 11:45 »
Steve, when you say airbox do you just mean the whole engine cover/intake assembly? I've had that off plenty of times. Am I right in thinking that if I have the replacement part in front of me i'll be able to spot original one quite easily?
I'm fairly handy with stuff and it sounds pretty easy but it's always nice to have an idea about the job before you start.
Cheers mate
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline Saint Steve
« Reply #24 on: 15 June 2010, 12:20 »
Cheers mate
Yes mate, the engine cover contains the air filter :wink: as soon as you take it off , look at the rocker box (top) and its in the middle towards the front :wink:
Let us know how you get on  :smiley:
Offline flyingzard
« Reply #25 on: 15 June 2010, 14:17 »
Is it a butterfly type valve as in the MK4 PCV valve. If so it should be possible to give it a good clean?
I am surprised that it has clogged up assuming it is that as my car has only done 13000 miles  :huh:
Offline Saint Steve
« Reply #26 on: 15 June 2010, 15:41 »
doubtful tbh at such a low mileage. although if its remapped, i would.
« Reply #27 on: 16 June 2010, 07:34 »
Cheers mate
Cheers mate. Ordered the part, will let you know how I get on. If there are no pictorial guides on how to do the job, perhaps I should do one????
Offline flyingzard
« Reply #28 on: 16 June 2010, 08:43 »
Yes please as i shall be embarking on this job ASAP as well  :smiley:
Going to have a look at my existing one first to see if it will clean up assuming that is possible of course.
Offline Saint Steve
« Reply #29 on: 16 June 2010, 14:35 »
The diaphragm is enclosed in a circular housing which if you open it up, you wont be able to put back together, so best to get new one and then prise open with a screwdriver to look at the Rubber Diaphragms condition.
Mine when it went was leaking between the two halfs of the housing, rather then it actually having a tear or split in it.
