Author Topic: dead at the mo  (Read 3194 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
dead at the mo
« on: 19 December 2004, 17:23 »
hey all my pc has been dead still is i am at my m8s
but the car is also dead
was drivin hom eother night about 50-60
when i heard a noise n it got louder n louder
n was slowin me down so i pulled over
and it was like a tractor so i got towed home
by a 1.0 fiesta pulled it all over lol.
thought it could of been a cylinder or summat
drove it to work just got there
the head gasket had blown and worn the head
n i cant find a head near me
so i am gettin another engine put in soon hopefully
next week maybe but i need piston rings doin aswell
but i know someone who is breakin 2 gti's up
so i am gonna enquire there :sad:
Offline VR6_ROB
Re: dead at the mo
« Reply #1 on: 08 January 2005, 15:45 »
still dead the so called mechanic put in another head i sourced got the timing out quarter of a inch or summat and bent the valves in the other head
so its in the garage now got it brought home on a truck gettin done tomorrow hopefully
Offline piggy
  • What you lookin' at sonny?
Re: dead at the mo
« Reply #2 on: 08 January 2005, 22:17 »
Ouch. Expensive cock up by , an Ex mate? :shocked:
How much is it setting you back, sounds costly :cry:
Offline VR6_ROB
Re: dead at the mo
« Reply #3 on: 15 January 2005, 14:03 »
the guy wanted 100 to fix it but he got nowt coz he bust it more
70quid for the head
41quid for plugs n leads
had new tensioner 25quid
12quid for belt
17quid for gasket set
rocker gasket forgot the price
right need help off you experts now
i got the car brought home on a truck 45quid
what the guy at my work had done was he took
that plastic cover  off my old head with the timing mark on
and put it on the new head (i never new) so he cocked up the timin
i had it checked over the valves are ok.
my friends dad did the timin spot on n it fired up
but now i need help
because it sounds like a sack of sh!t
exhaust was poppin like a rally car and it keeps cuttin out
and it is flat as a fart no power when i put my foot down
so i dont no wot it cud be i just bought and fitted
new plugs and leads and gonna do a engine flush soon
 :cry:
Offline carrie
  • i can see into your soul and its not good
Re: dead at the mo
« Reply #4 on: 15 January 2005, 15:41 »
did the valves hit the pistons when the timing was set out i.e. marks on the pistons as the valves could still be bent it only needs a slight bend to stop the valve sealing.
are you absolutely sure the valve and ingnition timing is correct?
assuming your timing is correct i would do a compression test (preferably leak down test) to ensure the valves are closing properly ad are not leaking due to the being slightly bent.
its a bit late to say this now, but this is why when changing heads or cam belts its good practice to remove to spark plugs and turn the engine over by hand before starting the car up. as then if valves hit pistons it is slowly and unlikely to do damage.
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Offline VR6_ROB
Re: dead at the mo
« Reply #5 on: 15 January 2005, 16:12 »
the valves were checked and they are fine.
the compression was 150 -160 i think so thats fine
and it was turned over by hand to start with and the timin
is spot on and it was done with a timin light afterwards
and it seemed fine
Offline Mr Blue
Re: dead at the mo
« Reply #6 on: 15 January 2005, 21:27 »
are the leads in the right order?
Offline VR6_ROB
Re: dead at the mo
« Reply #7 on: 15 January 2005, 23:19 »
yep
Offline VR6_ROB
Re: dead at the mo
« Reply #8 on: 16 January 2005, 13:39 »
right i been out this mornin and put in engine flush then emptied all the oil n refilled it with new stuff
and engine sounds fine but exhaust makin a poppin noise when i go to the back to listen echoey
also it wont fire up like it used to str8 away
just taken it out down the bypass got 70 n that was it
so any ideas on wot i can do next
could the exhaust have something to do with it
makin it loose power or makin it cut out?
Offline VR6_ROB
Re: dead at the mo
« Reply #9 on: 21 January 2005, 18:57 »
FIXED!!!!! ignition timing and a vacuum hose runs great now
good to be back on the road after 6 weeks
