Author Topic: Damsel in distress  (Read 2893 times)
Offline GTI_H_MK4
Damsel in distress
« on: 13 June 2010, 10:31 »
Hi, im a newbie, female and blonde so bare with me! Lol.  :huh:
I have a Golf GTI MK4 1.8 Turbo (98 S reg) and am having a few problems, grrrr. I've had it for 6 years now so don't want to part with it, i just want it fixed.  :sad:
It is juddering /misfiring and just beforehand i can hear a clicking in the ignition area. It seems to happen after it's warmed up although the temperature seems to be messing about a bit as well. It also keeps cutting out on me when slowing down/stopping, the revs drop out and it cuts out, though at the moment it starts again (thankfully as every time it happened yesterday was on a roundabout!).
Any ideas?????
Offline johnson6672
Re: Damsel in distress
« Reply #1 on: 13 June 2010, 14:09 »
Welcome, hope you get it sorted, post above in the mk4 section, you will get a better response, although i know what the first one will be, get the codes read and go form there, if you have a laptop go on ebay and buy a vagcom lead, they are about £15, it comes with the basic software to read and reset codes.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Deano2711
  • 1992 VR6
« Reply #2 on: 13 June 2010, 14:14 »
The cutting out at junctions etc will more than likely be the throttle body needing a damn good clean. As for the misfire then maybe coilpack or plugs and leads need changing. As said try getting a fault code reader to check for codes first but throttle body clean is free and easy to do. Do a search on here for a guide on how to do it. Welcome to the site as well.
Offline Agreeable Slick
  • Unit
« Reply #3 on: 13 June 2010, 14:16 »
coil pack.
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 13 June 2010, 14:44 »
It sounds like you have a few small issues there. A quick fault code scan will reveal more details. First thing i'd do is clean the throttle body (check the mk4 maintenance section for a guide) and sort out the temperature problem. Funny things can go on if the ECU is seeing strange engine temperatures. If the needle movement is erratic then look at replacing the coolant temp sensor but if it's stable yet refusing to sit at 90 degrees it points more towards the thermostat being faulty.
The clicking around the dash area could be the fuel pump relay or an ignition switch problem. Also check the condition of the battery connections as well as the fuses that sit on top of it. Faulty maf sensors and ignition amp modules are common causes for misfires and judders with your engine.
Offline vwprime
« Reply #5 on: 13 June 2010, 15:44 »
Hi there H
Big welcome to the forume  :smiley: (waving hand)
Like what others have said beofr with posable things to check i would do that? Where about in the UK are you? If around the London/South aria i could maybe check the problem with my laptop and see what comes up and then you would have a better understanding at what to change and fix you MK4 :)
TRANSFORM, & ROLL OUT!
Offline luvmygti
« Reply #6 on: 14 June 2010, 10:08 »
MKV GTI/ 3 Door/ 18" Monza II/ Full leather/ heated seats/ Manual/ Arm rest/ 6 Disc changer/ Cruse control/ Highline MFD/ Xenons/ Dog's Nuts!
Offline GOLF_STU
  • THE_GIT
« Reply #7 on: 14 June 2010, 21:45 »
welcome along  :cool:
V TEC KICKED IN Y'ALL!!!
Oddie
« Reply #8 on: 17 June 2010, 17:23 »
Hi
Offline VR6_Wherry
« Reply #9 on: 18 June 2010, 11:28 »
Welcome to the forum  :cool:
