Author Topic: suspension tops  (Read 1306 times)
dellenty69
suspension tops
« on: 12 June 2010, 00:27 »
with my last car i had to use the old OEM strut tops and rubbers on the new suspension (JOM/hot tuning, race land, all the same, manufactured in same factory!)
i just got my self a set of hot tuning coil overs, and i have fitted them with the original rubbers again.
im just curious as to if you lot use the rubbers, and if so what order you put them on.
iv got: (starting at the bottom)
silver alloy suspension top
little bearing
rubber cup
flat 21mm nut
car body
upper suspension cup
21mm securing suspension nut
this sound right to you?
its all on there fine, although i haven't set the ride height yet (need to clear arb etc)
i have 235/35/19 r8 wheels and the coil overs at the lowest setting. looks lovely, but at this point in time its a lovely looking paper weight.
thanks
james
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: suspension tops
« Reply #1 on: 12 June 2010, 10:06 »
unlkess you have uprated arb or adjustable drop links you will have issues.
That sounds the right order to me mate, however i would for peice of mind put new strut tops and bearings on
Offline northeast_gti-t
  • "1.8T AGU"
Re: suspension tops
« Reply #2 on: 12 June 2010, 12:52 »
I'd agree with hulmie  :wink: for what the parts cost it would be wise to fit some new ones i had all the top mount bushes/bearing changed when i had my coillies fitted as i knew that at nearly 60+k the originals would be getting past their best
2000 Mkiv GTi 1.8T AGU
Offline dub whore
Re: suspension tops
« Reply #3 on: 12 June 2010, 13:08 »
little bearing
rubber cup
flat 21mm nut
car body
thanks
james
dude did you have issues with the wheels rubbing the springs? i had to get spacers for mine as they are 235 and rubbed bad
Offline vwfiend
Re: suspension tops
« Reply #4 on: 12 June 2010, 13:23 »
They will do, I have 225x 18 and I can get a Tuzla pack between the adjuster and tyre! All good though as that gap never changes. You'll get raped on decent tyres  :laugh:
Offline wakeboarder15
Re: suspension tops
« Reply #5 on: 12 June 2010, 18:59 »
you dont happen to have part numbers for the top mount bushes/bearings do you?
doing coilies some time in the next week
dellenty69
Re: suspension tops
« Reply #6 on: 12 June 2010, 23:38 »
Excelentx they where replaced on last service, along with rear Adel bushes. So arnt ancient. Greased them back up and there good as new.
Yeah I would of had issues, but I have 5mm spacers on front.
I have heard talks of the r32 ARB helping with issues along with adjustable drop links.
James
