Author Topic: Auto Locking Doors  (Read 1336 times)
Offline edition_30
Auto Locking Doors
« on: 10 June 2010, 19:01 »
yesterday i had my passenger side door lock replaced as the door would sometimes not open. im sure before hand that if i forgot to lock the doors that they would automaticly lock.. This is now not the case.. can it be reactivated via highline?
Offline Colinv
  • Qualified VW mechanic
Re: Auto Locking Doors
« Reply #1 on: 12 June 2010, 22:00 »
Hi mate this needs to be re activated through the onboard supply unit using guided functions in vagcom. Changing a door lock should not really have affected that option though as the lock isn't a codeable part of the car
Offline nr123
« Reply #2 on: 12 June 2010, 23:53 »
If it's the anti-hijack feature you are talking about then yes this can be set in the highline computer again, under the convenience menu. None of the doors lock when driving off? Then you probably need to just set it again, I'd be worried if only that door didn't lock.
