Author Topic: compression test results  (Read 1709 times)
Blue MK2
« on: 17 December 2004, 17:48 »
Just done a compression test at college on my mk2. 8v digifant if that helps.
got these readings... started with the left piston and finished on the right
160 170 165 160
is this good?
Also had a water leak and they done another sort of compression test. They also fixed it....Bonus!
VeeDubGTI16v
Re: compression test results
« Reply #1 on: 17 December 2004, 18:18 »
good enough i think, its when is dramatically down on the others theres something wrong :undecided:
Offline mk1
« Reply #2 on: 17 December 2004, 23:02 »
They are ok.
Steve.
Offline richandhazel
« Reply #3 on: 18 December 2004, 02:04 »
160 170 165 160
is this good?
Also had a water leak and they done another sort of compression test. They also fixed it....Bonus!?
They're fine and the difference between cylinders is well within tolerance :wink:
free
« Reply #4 on: 18 December 2004, 02:15 »
just out of intrest, what should they b out the factory? :smiley:
