Author Topic: Mk5 GTI DSG Whining  (Read 6551 times)
Offline Jonotaff
Mk5 GTI DSG Whining
« on: 09 June 2010, 21:42 »
Hi All,
Hope you can help........
My GTI is has started to make a whining noise above 55mph.  :shocked:
Symptoms:
1) Does not happen at standstill revving in neutral (Turbo's ok?)
2) Rises in loudness with increase in speed
3) Could be a bearing?
4) Transmission? (Gulp!)
5) Not climate control related
6) Had two new front tires 6 weeks ago but didn't notice the problem at the time, no rumbling, handles the same - possible source of issue?
Cant explain the noise apart from it is a whine!! Not much help?? lol
Car booked in for a look on Friday but thought you (the experts) might have some idea or have had a similar experience.
Offline bacillus
Re: Mk5 GTI DSG Whining
« Reply #1 on: 09 June 2010, 22:05 »
IMO either bearing or depending on your make of tyre, tyre noise.
Without traction power is nothing!
Offline Jonotaff
« Reply #2 on: 09 June 2010, 22:10 »
Bacillus,
thanks for the response........hope its either TBH - not too expensive!!
Offline Steve30
  • Ed30 .
« Reply #3 on: 09 June 2010, 23:06 »
It sounds like a wheel bearing to me to? :undecided:
Tiguan quicker than the Golf
« Reply #4 on: 10 June 2010, 00:07 »
Wheel bearing or worse case diff bearing.
Offline Hurdy
« Reply #5 on: 10 June 2010, 00:12 »
If the bearing is going one alloy will be generally hotter than the other after a 10 minute spin in the car. Check whilst wearing some thin gloves or a cloth.
Like Bacillus says, it could also be tyre noise. My R888's sounded like a tractor wheel and gave a regular whining noise, so it could also be that. Again, you could check this out if you could borrow someone else's front alloys/tyres for a short spin. If the sound goes, it is the tyres :smiley:
Seat Leon Cupra Black 290 DSG
Offline Jonotaff
« Reply #6 on: 10 June 2010, 10:36 »
Thanks for the answers, appreciated. will update with the diagnosis
A bit off topic............
Nice stats Hurdy!! 380bhp through a DSG, wow, thought it couldn't be done (max torque of 300nm??). How did you do it?
Thinking of doing the Bluefin/Miltech upgrades later this year (C. 240bhp) - think this is enough!!! Then again how much is enough?!!
Cheers again for the help
Offline Hurdy
« Reply #7 on: 10 June 2010, 10:43 »
The dsg box as standard is rated at 350nm. With REVO software file for the DSG it is uprated to take 600nm. I'm running 562nm at the wheels!
I'm also running a stronger diff (quaife) and bearings.
Offline Jonotaff
« Reply #8 on: 10 June 2010, 11:42 »
Nice....will send you a PM for advice when the time comes for upgrades.
This is my 7th GTI (2 x Mk1s, 3 x Mk2s, 2 x Mk5s)! could say i'm a bit of an enthusiast!! The DSG is simply awesome IMO
My last Mk2 (8v) was a real Q car spent 1000's under the shell....Brakes, suspension, new electronic Injection, Stage 2 gas flowed head, forged pistons, uprated bottom end, race cam, powerflow custom exhaust.........completely standard outside, just de-badged.........
Want to achieve the same thing with this one, not flash, not mad, just quick!!!
Ideally 260bhp/290nm would be spot on - any initial thoughts?
Offline Jonotaff
« Reply #9 on: 10 June 2010, 16:00 »
Just been out for a spin (25mins) and the alloys are all cold?? So based on the above doesn't suggest a bearing issue?
