Author Topic: Goodyear Eagle F1 Tyre Advice  (Read 1777 times)
Offline 0scar
« on: 09 June 2010, 17:12 »
Hey,
I know there are loads of topics regarding tyre size etc. Just need some more specific advice.
I have 4 Goodyear Eagle F1 GSD3 Tyres on G60 steelies. 195/50/15.
Both the fronts need changing now, however, the GSD3 have been discontinued and are hard to get hold of on such short notice.
The garage can get 195/45/15 (GSD3) however, this would mean different profiles on front/rear.
What do you reckon?
If thats not a good idea, what tyres would you recommend?
I am really happy with the performance/feel/aesthetics of the Eagle F1 tyres, not looking to downgrade.
Will be ordering tonight/tomorrow, advice highly appreciated!
Offline dom
  • Back in a Mk4
Re: Goodyear Eagle F1 Tyre Advice
« Reply #1 on: 09 June 2010, 17:13 »
Are the fronts illegal? If not can you not just swop the front and backs over to give you enough time to source the correct ones?
Offline 0scar
« Reply #2 on: 09 June 2010, 17:22 »
Both the fronts are illegal. Will not be driving on them till they are replaced.
The garage can get most tyres same day delivery just not the ones I currently have.
Always the way!
Offline DOA
« Reply #3 on: 10 June 2010, 17:04 »
Only issue is the very slight change in your rolling radius which will throw the speedo out a tiny bit. Oh and when you wear the fronts out next time you cant then fit them on the rear and vice versa because that would look stupid  :rolleyes:.
Offline adamfernadam
« Reply #4 on: 10 June 2010, 21:28 »
DOA is spot on..it will just knock your speedo out slightly..there are calculators online to tell you exactly how much
Offline danny_p
« Reply #5 on: 10 June 2010, 22:49 »
mixing profiles is leagal as long as they stay on the same axel  but tbh some how one day it'll find a way to bite you in the arse
all the VW's have gone bar 1.
Offline matg340
« Reply #6 on: 12 June 2010, 00:00 »
You have to put the bigger size on the back of the car for legality , but tbh there are better tyres out there , have a look at yoko parada 2 thems be awesome .( and cheaper than 45 series f 1, which btw are mostly made in china now and are therefor quite sh!t )
preserve wildlife.......PICKLE A SQUIRREL !!!!!!!!!!!!
Offline dTEA
  • back in an MK5
« Reply #7 on: 12 June 2010, 07:09 »
I wouldn't do it...will be slightly noticable side on.
Everything else has been said. I would think about the wet perfromance of the Tyres you choose if a daily as yokes are not always great in the wet, excellent in the dry mind but wear factor is also an issue
Edition 30 / T5 T32 Kombi
Offline tweed
« Reply #8 on: 12 June 2010, 10:28 »
I once had 195/55/15 on the front and 205/50/15 on the back. didn't really notice it to be honest.
Your only going to be a little bit slower than what your speedo says.
 Buy them, stick them on the back and wear the 195/50's down the replace them with 45's.
