Author Topic: Retarded Volkswagens ?  (Read 1219 times)
Offline Colin
« on: 17 December 2004, 13:35 »
I'm not suggesting it is retarded, but occasionally when i accelerate in my 8V, the engine bogs down as though the distributor is not advancing or as if the choke was on, then all of a sudden whoomp away it goes.
This doesn't happen all the time but when it does it's annoying, so anyone got any suggestions before i lift the bonnet to fiddle with it on christmas day?
Merry christmas All ! :kiss:
laserblaster
Re: Retarded Volkswagens ?
« Reply #1 on: 25 December 2004, 06:38 »
could be either petrol or ignition side!
check for loose wires.....
if all look ok...... you could try a high rev down the local 70mph road!
but make sure the engine is hot and your oil level is ok before doing so!
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 27 December 2004, 19:05 »
it's just pretending to be a turbo imating lag  :grin:
free
« Reply #3 on: 28 December 2004, 01:50 »
illd put sum injector cleaner in if i was u mate, think that will fix it :wink:
