Author Topic: Launch control broken?  (Read 2856 times)
Offline weston
« on: 08 June 2010, 09:36 »
My 2005 GTI of 6 weeks doesn't seem to be able to do a launch control start. I follow the steps but the engine will only rev to around 1500rpm and I can feel it trying to pull away. Am I doing something wrong? I tried in S mode, with ESP off and left foot braking. I thought all DSG's had LC. Thanks for any responses.
Offline bacillus
Re: Launch control broken?
« Reply #1 on: 08 June 2010, 11:42 »
Hmm, did you try in manual mode as well?
Without traction power is nothing!
Offline GtiJames
« Reply #2 on: 08 June 2010, 11:47 »
im not sure when mk5 dsg gti's got launch control but i have heard that the older models did not have the function..
does your car have the flappy paddles?
all is not lost though, as if you get a revo dsg map then this will enable launch control for you, along with a few extra goodies such as faster up and down shifts, no automatic up shifts and torque delimit   :cool:
Offline clint4one
« Reply #3 on: 08 June 2010, 12:37 »
I have the same problem in my 2009 r32, put it in S mode turn trac control off, i can only get it to about 1000revs n it feels like the only thing stopping me going is the brakes.
Other than this tho the clutch/brake works fine n the gearbox is silky smooth.
2009 MKV R32
Offline weston
« Reply #4 on: 08 June 2010, 15:21 »
Ok just been out again, any excuse will do for a drive! LC doesn't work in S or D but in manual +/- it definitely works :) Thanks for the advice!
Offline PenguinGTI
« Reply #5 on: 10 June 2010, 22:42 »
I might add that it makes a difference that you put the tc off first and then into S or Manual mode. Or at least on my car it does. If I select manual/ s first and then turn off tc then it wont work.
Offline weston
« Reply #6 on: 10 June 2010, 23:38 »
That must've been where I went wrong then.
Offline gti265
« Reply #7 on: 12 June 2010, 04:27 »
you can have it uploaded by vw if you request it, some garages may charge you, but normaly free if you are having service :)
candy white 2007 golf gti, fully colour coded, tinted windows and black alloys :)
