Golf mk3
hardmonkeys
Lost locking nut socket....now i can not get my wheels off
Topic: Lost locking nut socket....now i can not get my wheels off (Read 957 times)
fransnz
07 June 2010, 19:00 »
I have some how lost the socket to remove my wheels.
Its got round bolts with three pins in the center.
Has any one had the same problem.....how the hell do i get them off?
05 Black GTI DSG 5 Door.
kells
Guest
Re: Lost locking nut socket....now i can not get my wheels off
07 June 2010, 19:12 »
bang a 16 or 17mm socket over and remove that way.
or get another key and remove 2 of the pins that are in it so the remaining poin fits into one of your holes
these are crap locking wheel nuts, had same happen to me, now use mcguard ones
zdebx
07 June 2010, 19:16 »
Try Kell's method or they will probably need to be drilled out.
As far as I know, they're standard locking nuts that you get from VW. Proper crap, those holes widen themselves after you put/take off the bolts a few times. Then the key keeps spinning, without pushing the nut
Yeah, McGuard ftw
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here >
http://www.golfgtiforum.co.uk/index.php?topic=161711.0
dannyboy2501
GTI forum regular
Blackberry IM pin 228D8231
07 June 2010, 19:20 »
Remove outer shell with small chisel them smash a
17mm impact socket over the top and wind out job done
gazpowells
07 June 2010, 19:56 »
drilling them out is hard work
just wack a socket over them, should have no problem getting them out
al_bey
GTI forum regular
07 June 2010, 21:14 »
http://www.golfgtiforum.co.uk/index.php?topic=154675.msg1445882#msg1445882
Golf mk3
hardmonkeys
