Author Topic: Shocks, golf/coraddo?  (Read 1978 times)
Offline Diamond Hell
  • Opinions я Us
Re: Shocks, golf/coraddo?
« Reply #10 on: 13 June 2010, 12:59 »
the bit that the spring is supposed to sit against is too small in diameter,
Offline Haribo!
« Reply #11 on: 13 June 2010, 14:09 »
im still not sure what you mean, i really dont know a great deal about cars
if the spring cap is the bit that sits against the spring then I already have them as theyre part of the mounts arnt they? on my new mounts which are golf mk2 ones, but as i said, theyre too small for the spring....  :undecided:
  • Opinions я Us
« Reply #12 on: 13 June 2010, 16:19 »
No, the spring cap is a piece of pressed metal.
It bolts down on the strut first, then the top mount goes on.
Offline Haribo!
« Reply #13 on: 13 June 2010, 16:29 »
ah ok, so i need spring caps as well as mounts, gotcha, thankies :D
  • Opinions я Us
« Reply #14 on: 13 June 2010, 16:41 »
Remove old strut assembly, place side by side next to new bits and make sure they're the same before re-assembly.
Saves making a tit of yourself and doing the job more than once.
Remember to get the front end properly set up once you've done the job.
