Author Topic: 1.8 Brake Discs & Pads  (Read 2170 times)
Offline zdebx
« on: 06 June 2010, 17:56 »
Soooo my brakes are quite sh!t, and I've decided to get new discs and pads.
Did some searching here and there, but couldn't find exactly what I'm looking for.
Firstly, are there any particular brands you would recommend? I'm assuming Eicher stuff is crap, since it's really cheap? (had a look on ECP). What about PAGID? lol, never heard of them...
Then, where should I buy all the stuff from? eBay, ECP, GSF?
Finally, is there any point of getting drilled/grooved discs and fancy green stuff pads?
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
kells
Re: 1.8 Brake Discs & Pads
« Reply #1 on: 06 June 2010, 18:25 »
just put mintex pads and discs on mine, very happy with them
Offline zdebx
« Reply #2 on: 06 June 2010, 18:37 »
Are the pads same size for all mk3's? And what size discs do I need? 239mm?  :shocked:
kells
« Reply #3 on: 06 June 2010, 18:45 »
not sure matey, in just asked at my local oldskool motor factors, i know the gti discs are 280 and 288mm not sure on yours tho
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 06 June 2010, 19:19 »
I ran 256mm ate powerdiscs and std pads on my old 1.8.....both from ecp
Offline Leon27
« Reply #5 on: 06 June 2010, 19:44 »
I had Jurid or Pagid, one of them, from ECP together with normal ATE discs on my 1.8 GL. Squeaked like a btch. Not recommended  :sad:
« Last Edit: 06 June 2010, 19:45 by Leon27 »
Offline zdebx
« Reply #6 on: 06 June 2010, 20:20 »
Do I need to change anything to run 256mm? Standard ones are 239mm...
And should I get solid or vented?
Thanks Leon :) So ATE stuff seems good?
kells
« Reply #7 on: 06 June 2010, 20:27 »
you need like for like, any bigger wont fit unless you change the calipers
id just get mintex pads and mintex discs for it, direct replacements, think you can even get them on ebay
Offline Leon27
« Reply #8 on: 06 June 2010, 21:06 »
Just driving down a road without my foot on the brake pedal would cause squeaking! Definately the pad in the carrier was to blame. ATE make BMW components so I thought the combination would be right as it was very cheap from ECP, but you get what you pay for.
Go with Mintex :) or get VW stuff if you know someone who can get you discount...
VW BUSH
« Reply #9 on: 07 June 2010, 20:47 »
I just fitted Pagid front discs on my 8v, good discs good price but be careful buying from ECP as i had to spend a good while convincing them gti's were 5 stud and not 256mm........
Check their site it specs 4 stud 256mm discs for 8v gti  :grin:
