Author Topic: vag-com 409.1-S  (Read 5704 times)
Offline mick ov mids
vag-com 409.1-S
« on: 06 June 2010, 01:29 »
iv downloaded a cracked version on vagcom but when i try to connect to a port its coming up as not connected and on the main screen the only thing i can do is go into options but it's asking me to select a port, then theres the protocol options and a shop name  :undecided: how do i get past all this? i only want to read the ecu for faults  :sad:
thanks mick
[img width=500 height=200]http://i836.photobucket.com/albums
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: vag-com 409.1-S
« Reply #1 on: 06 June 2010, 10:17 »
Theres been loads of topics about the port problems, usually an easy fix. Have a look here it may help..
http://www.golfgtiforum.co.uk/index.php?topic=134470.0
Offline Deano2711
  • 1992 VR6
Re: vag-com 409.1-S
« Reply #2 on: 06 June 2010, 11:00 »
I have had this problem with my Vag Com lead since I bought it. Something about you needing to change the com port setting and it has to be a port which is not shared. I gave up and bought a fault code reader which is easy. I live by Russell's Hall Hospital and you are welcome to come over this afternoon to read any codes Mate. Just let me know
