Golf mk4
Wazzzer
STRUT ADVICE
Topic: STRUT ADVICE (Read 969 times)
jake
STRUT ADVICE
03 June 2010, 16:52 »
Hi guys
I have played around with my suspension an awful lot of the last 2 years!
But just wondering if there is any tricks of the trade i could pick up when it comes to seperating the strut from hub, and putting the strut back in the hub!
I find the only way to get the hub away from the strut is hit it down with a soft headed mallet!
And to be honest, i really dont know how to get the strut back in! I tend to drop the cars weight on it to make it push down?
Anyone any better techniques?
Thanks
Jake
Hulmie
White MK4 1.8T AGU K03s
Re: STRUT ADVICE
03 June 2010, 17:26 »
put a jack under the bottom arm and you can jack it back up to the strut whilst keeping the strut aligned.
As for removal then the method you use is what i do and would say most people do. Only other way i can think of is to unbolt the bottom arm and lower it down with the hub still bolted on at the balljoint.
jamie16v
Guest
Re: STRUT ADVICE
03 June 2010, 19:10 »
another tip i learned is to jack the other side up while removing too as the ARB will give more slack if the other side is raised, better still remove one of the drop links.
johnson6672
Re: STRUT ADVICE
03 June 2010, 19:15 »
Hulmie's way to get back on is what i do, to remove, chiesel or flat point screw driver in the gap at the bak of the hub to open it out, then hit away til it comes of, also always remove the drop link for extra movement.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Golf mk4
Wazzzer
STRUT ADVICE
