Author Topic: Somethings not quite right with the feel of my brake pedal  (Read 966 times)
Offline Andy Mc
I'll try and describe this the best way I can not knowing how my brake pedal mechanism is put together.
When I press the brake pedal the brakes work absolutly fine but every so often, I'm feeling what I can only describe as something coming lose or moving that is attached to the brake pedal itself (i.e. the cables snapping (if there is one, or the clip holding the cable in, is on its way out)). This is an intermittant problem and happens normally after first setting out and has happened some way into the journey.
Seeing as this is the brakes, I would like to fix this fairly soon. Has anybody got any ideas as to what this could be...??   :huh:
'90 16v
Veedubgt18v
Re: Somethings not quite right with the feel of my brake pedal
« Reply #1 on: 15 December 2004, 08:07 »
have a look under the dash at the pedal box could be a worn linkage?
