Author Topic: 5 speed to 6 speed gear box conversion  (Read 8364 times)
Offline firefox
« on: 03 June 2010, 09:23 »
hi, my gear box needs refubing and i have the chance of a 6 speed 02m box to replace it with flywheel etc. was just wondering if this box would fit???
i have a 1.8gti 51 plate aum engine code any advice b4 i go ahead would be appreciated
thanks peeps :)
Offline Rhyso
Re: 5 speed to 6 speed gear box conversion
« Reply #1 on: 03 June 2010, 09:26 »
covered in a thread about a week ago but.....
driveshafts, starter motor, flywheel, clutch etc etc
In other words not worth the effort  :smiley:
Offline firefox
« Reply #2 on: 03 June 2010, 14:40 »
the kid whos selling the conversion says it coomes with everything that is needed, just wanted to check that the box in question would go into a mk4.
« Reply #3 on: 03 June 2010, 16:20 »
Yes but you need to change a lot of parts
Offline linz
  • vee-dub
« Reply #4 on: 04 June 2010, 10:36 »
i also thought tht the 1.8t's prefere the 5 speed box....
Offline richw911
« Reply #5 on: 04 June 2010, 18:36 »
It is better suited  :smiley:
Offline Purely VAG
« Reply #6 on: 05 June 2010, 01:15 »
Its better suited to a standard 150bhp turbo YES
Soon as you remap or have a k03s or bigger then NO  - The 02M is more suited.
Hence they fit 02M's on everything fitted with an S or above.
Basically what you need for conversion...
* 02M FWD Gearbox
* 02M 6 Speed Gear Linkage
* 02M Flywheel(4cyl.)
* 02M Clutch
* 02M Starter Motor
* 02M Front 2WD Driveshafts
I did say RING me if you wanted to know anything, Saves me typing it out all time but each to there own....
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
