Author Topic: someone with etka  (Read 2077 times)
Offline navmk4gti
someone with etka
« on: 02 June 2010, 21:28 »
can someone with etka check this product code for me 06A 103 469 B
it is a rocker cover but want to know what models it will fit  :wink:
Offline Purely VAG
Re: someone with etka
« Reply #1 on: 02 June 2010, 21:38 »
Part number = No results.
May have been superseeded, I checked manual listings for VW and isnt there but may be from other VAG.
If it fits AUM coilpacks then people will know if it will fit theres.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline navmk4gti
« Reply #2 on: 02 June 2010, 21:39 »
it came of a seat leon 1.8 20v turbo engine 180bhp i belive they are.. so not sure if will fit mk4 engine codes.. as im sure the leon engine is as same as a mk4's  :undecided:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 02 June 2010, 21:51 »
Aum cam covers are the same part number but the last letter being an 's' agu cam covers are slightly different where the coil packs locate i'm not sure wether you can use aum covers on an agu
2000 Mkiv GTi 1.8T AGU
Offline navmk4gti
« Reply #4 on: 02 June 2010, 21:54 »
hmmmm intresting.. i wouldv personally thought all the 1.8 20v engines have the same rocker cover as the coil packs are in the same place just the way they are fitted is different.. in my agu its like bolted down where as my mates aum there kinda free to pop up when they feel like but the cover looks identical  :undecided:
Offline Purely VAG
« Reply #5 on: 02 June 2010, 22:20 »
I was advised that they were different rocker covers.
Offline richw911
« Reply #6 on: 02 June 2010, 22:21 »
That will  be an AUQ  :smiley:
Offline richw911
« Reply #7 on: 02 June 2010, 22:23 »
ALL 1.8T rocker covers have the bolt holes that the AGU uses  :smiley:
Offline navmk4gti
« Reply #8 on: 03 June 2010, 01:22 »
so will this rocker cover fit em all  :smiley:
