Author Topic: Glovebox removal  (Read 4292 times)
Offline Micaerin
Glovebox removal
« on: 01 June 2010, 12:01 »
Has anyone ever attempted replacing a glovebox?, or is there a how to anywhere
thanks in advance :wink:
2007 Golf GTI DSG Steel Grey
Offline Sootchucker
Re: Glovebox removal
« Reply #1 on: 01 June 2010, 16:16 »
Here ya go...
Removal
–   Switch off ignition.
–   Remove side dash panel cover on front passenger side
–   Release sill panel moulding from body, in area of transition to lower A-pillar moulding:
–   Remove A-pillar lower trim on front passenger side
–   Remove centre cover
–   Remove the seven bolts -1-, -2- and -3- (1.5 Nm).
–   Slide glove compartment outwards onto limit stop -arrow A-.
–   Detach glove compartment -arrow B- from dash panel.
–   Disconnect wiring harness from light and contact switch.
–   If vehicle is equipped with front passenger airbag disabling, disconnect wiring harness from key switch.
–   If vehicle is equipped with glove compartment cooling, disconnect air conditioning duct from glove compartment.
–   If vehicle is equipped with a footwell light, disconnect wiring harness from light.
