Author Topic: Well Its All Sorted  (Read 2304 times)
Offline northeast_gti-t
  • "1.8T AGU"
Well Its All Sorted
« on: 31 May 2010, 00:00 »
Well as some of you were aware i'v basically had an issue where my boosts been hitting 5psi only  :cry: and comes and goes ok one minute and then another back down to 5psi again  :laugh: so i needed to get to the bottom of this and get it boosting as it should so thursday i got it booked in and yesterday i made a trip down to the midlands car hit requested boost 5 miles into my journey then before getting on the A1 it was 5psi again stopped for some v power and got going cars boosting again  :rolleyes: all the way down okay so once there chris & ben give it a check for anything obvious etc bit of a chat and then some more searching chris found alot of movement on my forge tip  :huh: and investigated further under the car as he had an idea also a check on vag-com and lo and behold the 17705 had returned  :sad: basically chris wasn't happy (neither have i been since fitting :rolleyes:)with how the tip was sat and underneath became clear it was a little twisted on the inlet stub of the t/c so him and ben pulled it off and both re-aligned it and gave it a good tighten up as chris said he got it to go tighter before re-alignment had a look at the charge hose to pancakepipe that i fitted about 3 weeks ago and it was bone dry  :smug: and well clipped in even pulling down heavy on it! so a run on the rollers then and i sat in with ben as to do some logging for chris what a feeling my golf beeing run in 4th up to nearly 7k (didnt look at speedo) :afro: for the power runs etc once done chris in detail explained virtually everything that was logged  :wink: everything performed as it should no issues!! even the std smic is up to the job at the minute car boosted okay
Well the result is im producing 200bhp @ wheels and overall the car made 225-230bhp & 260lb/ft torque
needless to say i was well happy!!
even better chris and me went for a run nice n damp esp/asr off  :evil: :evil: couldn't get it into limp mode and its now hitting 20/21psi holds n drops as it should fook me does it pull and feel strong!! so hopefully cars as it should be big thanks to both the lads for yesterday i had a good time and learnt alot too oh and best little mod of the day......ben noticed my centre heatshield was missing two of its clips causing it to rattle :embarassed: fixed with two plastic orange juice tops  :grin: :grin: quality does the job mind  :tongue:
« Last Edit: 31 May 2010, 00:03 by northeast_gti-t »
2000 Mkiv GTi 1.8T AGU
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
Re: Well Its All Sorted
« Reply #1 on: 31 May 2010, 00:48 »
Glad everything is sorted now mate, sounds like a couple of top mechanics you've got there :afro:
  • "1.8T AGU"
« Reply #2 on: 31 May 2010, 00:53 »
cheers :afro: yep i'm glad its all sorted to feels as it should do again and nice and quick  :lipsrsealed:  :grin: they are i think you would regonise them Chris & Ben
Offline richw911
« Reply #3 on: 31 May 2010, 10:56 »
Great stuff thumbs up to tuneside then!  :cool:
Offline Adam
« Reply #4 on: 31 May 2010, 11:51 »
:afro:
Down Hill From Here.
Offline DarkGti
« Reply #5 on: 31 May 2010, 12:11 »
glad you got it sorted matt, now the beast is back :wink:
  • "1.8T AGU"
« Reply #6 on: 31 May 2010, 22:05 »
absolutely  :cool: :smiley:
  • "1.8T AGU"
« Reply #7 on: 31 May 2010, 22:05 »
:afro:
cheers adam  :wink:
  • "1.8T AGU"
« Reply #8 on: 31 May 2010, 22:06 »
Cheers Ry  :wink: yes feels so much better it certainly is now  :evil:
