Author Topic: Removing everything to start again..  (Read 2573 times)
Offline Dave_IOW
« on: 29 May 2010, 21:23 »
Whats best product to completely strip all layers of wax / jetseal to start again, used the car wash at garage (no brush of course, just hot shampoo!) as thought that would contain a TFR, which would strip it all down, but didnt seem to strip anything.
From things i have read, claying will remove it, but wouldn't that just get the clay full of wax and dirty very quickly?
Would a proper drum of caustic TFR remove all these layers to start afresh, or would this g101 do the same job?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Dan J
Re: Removing everything to start again..
« Reply #1 on: 29 May 2010, 22:06 »
claying it is fine and if you do it straight after washing it shouldnt get very crappy, tfr will remove all of it though jetseal may still be present so washing it twice might be needed, when the cars dry you could over it with some finishing compound by hand which will help remove any left over wax/sealant that might still remain.
Offline Dave_IOW
« Reply #2 on: 30 May 2010, 15:12 »
Thanks Dan, will give TFR a go then  :smiley:
Offline Dan J
« Reply #3 on: 30 May 2010, 23:08 »
keep in mind you might have to do it twice and possibly go at it with some finishing polish to be sure its all removed properly.
Offline Dave_IOW
« Reply #4 on: 30 May 2010, 23:43 »
Will do thanks, any recommendations on TFR or is it all much of the same?
High caustic or low? much difference?
Offline Dan J
« Reply #5 on: 31 May 2010, 00:31 »
http://www.autosmart.co.uk/images/PDF%20Folder/Autosmart%20COSHH%20sheets/ACTIVE%20XL%20-%20SDS10518%20-%20GBR.pdf
above is the data sheet for AS Active XL. Bloody good stuff, very effective cleaner and gets all the crap off the car, can be diluted, dont allow it to dry on the car though and make sure you rinse it off thoroughly. this will definatly remove anything you've put on before.
Offline tony_ack
« Reply #6 on: 31 May 2010, 16:12 »
I used dilluted G101 to get everything off.
Worked pretty well - after I degreased, then washed there was no sign of beading at all.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline Dan J
« Reply #7 on: 31 May 2010, 17:48 »
no beading isnt a sure sign that all sealant is removed.
Offline VWKev
  • Please Support Non-Human Rights
« Reply #8 on: 31 May 2010, 17:52 »
Yep as Dan said thats not a sign, you can even get beading with Polish only.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
