Author Topic: Remap....DV Spring  (Read 2300 times)
Offline Big Tone
Remap....DV Spring
« on: 29 May 2010, 15:19 »
Quick one,
When the cars been mapped, stage 1, I need a yellow forge dv spring,
Can I use spacers to "stiffen" the green one temporarily?
and
Does anyone know the best place to buy just the yellow spring on its own?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
jamie16v
Re: Remap....DV Spring
« Reply #1 on: 29 May 2010, 15:31 »
i bought my yellow spring from a company on ebay but i have a feeling its a "forged" copy..
pm for the ebay name and see what you think.
they did send me a sticker but looking at the spring it just looked cheap, was only sprayed on one side where the green one i took out was green all over and the quality of paint looked alot better.
Offline Big Tone
« Reply #2 on: 01 June 2010, 12:50 »
Any advice?
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #3 on: 01 June 2010, 12:52 »
never tried it with spacers?  IMO its best to do it right and get the yellow spring.
Nick
 01455 617233
Offline Big Tone
« Reply #4 on: 01 June 2010, 12:53 »
Ta, may have a bit of an "experiment" then.  :laugh:
Offline Waffs1984
  • Spacers are for chumps...
« Reply #5 on: 01 June 2010, 14:37 »
I'd also recommend getting a yellow spring from Forge.
The issue with using spacers is not knowing the spring rate or if it is progressive (i.e. it gets harder to compress the more compressed it is if that makes sense). If the spring is indeed progressive then using spacers will limit the travel and ultimately mean that it is at a higher stiffness all of the time meaning it won't work as it should. Using spacers to reduce the length of a non progressive spring will simply shorten the travel and not make it any stiffer (the spring rate will remain the same regardless of travel).
HTH
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
