Author Topic: indicator noise  (Read 2196 times)
Offline apsmale
  • VW Golf MK4 1.9 GT TDI 115
indicator noise
« on: 28 May 2010, 19:09 »
would there be any reason for the noise your indicator makes while indicating to randomly come on every ten or so seconds?
Offline Dan_GTI
  • GTi addict formally known as yoof
Re: indicator noise
« Reply #1 on: 28 May 2010, 19:14 »
relays f**ked IMO
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline apsmale
Re: indicator noise
« Reply #2 on: 28 May 2010, 19:42 »
easy to fix or not?
Re: indicator noise
« Reply #3 on: 28 May 2010, 21:38 »
Yep relay / flasher unit and easy to sort.
Offline apsmale
Re: indicator noise
« Reply #4 on: 28 May 2010, 22:03 »
how do i go about doing tht, im pretty useless.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: indicator noise
« Reply #5 on: 28 May 2010, 22:23 »
change hazard switch, job done  :laugh:
Offline apsmale
Re: indicator noise
« Reply #6 on: 29 May 2010, 11:04 »
how do i change the hazard switch, i need it done this morning as gotta drive 200miles later and dont want it doing this the whole way.
as i said earlier im useless, once i know what iv gotta do tho im fine.
thanks
Offline Rhyso
Re: indicator noise
« Reply #7 on: 29 May 2010, 11:09 »
thin flathead screwdriver down one side of the hazard switch and pull out
Offline richw911
Re: indicator noise
« Reply #8 on: 29 May 2010, 11:10 »
If you have blank switch socket covers (black plastic covers) Pop off with a small screwdriver the cover nearest to hazard switch, then you can get your fingers in behind hazard switch body and easily pop it out (no damage or force necessary).
 Once the hazard switch is proud of the dashboard the hazard switch is removed by simply uncliping it from connector block.
Offline apsmale
Re: indicator noise
« Reply #9 on: 29 May 2010, 11:40 »
cheers guys, off to halfords it is then.
