The garage
Diagnostics - VagCom / VCDS
Rhyso
VAGCOM driver troubles
Topic: VAGCOM driver troubles (Read 3862 times)
Khare
Serious forum addict
The bear that khares
27 May 2010, 15:59 »
Right, had problems with vagcom so uninstalled vagcom (311.2) and the roos tech cable driver. Now when I put the cable in, I put the CD that came with it but it won't install the cable, says failed. Anyone have the driver to sort this out?
Adam
Forum addict
Re: VAGCOM driver troubles
27 May 2010, 17:15 »
What OS you got?
Down Hill From Here.
Khare
27 May 2010, 17:26 »
Vista.
I've got vagcom 311.2 and 409.1, 311.2 is fully activated thanks to a member on here, and 409 I can't find an activation button.
The garage
Rhyso
