Author Topic: Wont rev past 5000  (Read 4322 times)
Offline zippy
Wont rev past 5000
« on: 26 May 2010, 18:12 »
Hi folks, recently got myself a cheap 2.0 8V agg engined mk 3. Runs ok(ish) but doesn't like to tickover until its warmed up a little, and won't rev past 5k. I have checked the cam timing and this appers ok (including dizzy timing) so is it likely to be hall sensor or am i missing something?? Not got a vag com thingymajig yet, so if anyone in the Buxton/Derbyshire area feels like helping, then please shout up :wink: Cheers, Mart
If the hammer dont fix it, maybe the hammers broke?
Offline javalin
Re: Wont rev past 5000
« Reply #1 on: 02 June 2010, 13:03 »
been covered many times on the main mk3 forum - its either timing or crank/cam sensor fault I believe
Have a search
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline moutains
« Reply #2 on: 02 June 2010, 13:13 »
have you got a rev limited rotor arm
Offline javalin
« Reply #3 on: 02 June 2010, 13:14 »
no such thing?
