Detailing
Dodo Juice 200ml
Topic: Dodo Juice 200ml (Read 2257 times)
edition_30
Dodo Juice 200ml
25 May 2010, 22:08 »
I'm considering purchasing some purple haze which comes in 200ml form. My question is how long does it last, enough for more than one application?
Jimble
Forum addict
Re: Dodo Juice 200ml
25 May 2010, 22:16 »
Mate, i bought the 30ml panel pot of supernatural and i've done 4 coats on my mk6 and used less than a 3rd of the pot! you only need a little bit, i was amazed after i saw how small the panel pots were i thought i'd only be able to do exactly what it says on the tin but i was wrong!
Hope this helps!
Dan J
Pro Valeting and correcting paint since 95
25 May 2010, 22:17 »
purple haze is 250ml and purple haze pro comes in 200ml
if you put 200ml of purple haze on your car in one go i will beat you with my rotory.
jokes aside you will get between 25/30 layers if you apply it correctly.
edition_30
25 May 2010, 22:31 »
Thanks for the replys fellas.. Been using smart wax which has produced some good results. I'm also going for some poorboys black hole
Dan J
25 May 2010, 22:37 »
havent used black hole personally but have read very good reviews about it.
PH is an awesome wax
PH pro is smoother in consistency and will give you a bit more durabilty over the standard PH
edition_30
25 May 2010, 22:41 »
I have been Reading on the forum & it mentions appliying with a buffer. I have always applied by hand using applicator pads & microfibre towel to remove, does this sound ok as I'm trying to get rid of sone swirls too
Dan J
Reply #6 on:
25 May 2010, 23:06 »
applying glaze by hand is fine and will give good results but your polishing stage needs to be spot on to acheive this, you'll get a deeper gloss by applying it by machine ie DA or rotory, if you havent got one its still going to look very good applyed by hand
Detailing
Dodo Juice 200ml
