Author Topic: 5 door rear arch's  (Read 3023 times)
Offline dubvrs
5 door rear arch's
« on: 10 December 2004, 17:09 »
Right then people need some info.
On my 5 door gti (89) i am not putting the gti arch's back on. I was going to put on CL rear arch trims to stop stone chips and to go with my door trims.
When i was stripping the car i found the rear doors wanted replacing. I know have 2 rear doors to put on but they are the later spec without the holes for the trim. I also have a new set of front wings again without the holes for the trim. Now i am thinking of welding up the holes in the front doors to match as the car is having a full respray anyway.
What i want to know is (finally gets round to the question after a full esay? :grin:) do the small rear arch trims fit in the same holes as the bigger CL ones.
This is what i have at the moment.
Do thesesmaller trims fit in the same holes?
Veedubgt18v
Re: 5 door rear arch's
« Reply #1 on: 10 December 2004, 17:46 »
doesnt matter if the dont you could alwyas bond or glue them on?
Mixologist
« Reply #2 on: 10 December 2004, 22:39 »
Looking at it i say that they would, you might aswell try it and see, if it doesnt work try bonding it as ed said!
Offline dubvrs
« Reply #3 on: 11 December 2004, 13:26 »
Cheers boys for the info. Have to see as i dropped the car off at the bodyshop for phase 1 this morning.
