Golf mk2
fuel pump
Topic: fuel pump (Read 1843 times)
jimbo_jones
Just got here
fuel pump
09 December 2004, 21:43 »
hi
i'm the proud new owner of a 1991 gti 16v and was wondering if its the norm for the fuel pump to make a pretty loud buzzing. it seems louder on startup but doesn't go away.
last owner said this was norm and that it had always been like this with no probs
any info would be much appreciated
thanks
Gambit
Forum addict
Re: fuel pump
10 December 2004, 09:15 »
fit a new main fuel filter (?5) and try replacing the lift pump in the tank. ?20+vat from German Swedish French and is easy to replace
if the lift pump is on its way out it, then the main fuel pump has to work more, and therefore sounds louder.
tinman
Re: fuel pump
10 December 2004, 17:47 »
i think the preignition noise is the fuel pump being primed or something. it stops after 2-3 seconds and is normal.
if you can still hear the fuel pump then its probably on its way out. as far as i can tell, more and more people are changing the lift pump as they seem to be dying on older cars. i certainly changed mine recently.
Veedubgt18v
Guest
Re: fuel pump
10 December 2004, 17:55 »
yeah the noise when you turn the key is the system being pressurised. i would agree with tin and gambit!
jimbo_jones
Just got here
Re: fuel pump
10 December 2004, 18:48 »
thanks for your help, at that price i'll def look into changing the fuel pump and filters.
i presume that it'll be covered in my Haynes manual
cheers
Jimbo
crimp
Re: fuel pump
10 December 2004, 20:41 »
Mine makes a buzzing noise all the time ,and you are saying this should be quiet all the time?
tinman
Re: fuel pump
Reply #6 on:
10 December 2004, 20:54 »
generally - you shouldnt hear your fuel pump. put it this way, other than pre-ignition i've never heard it on any of my cars.
when i get back to the UK next week i'll start my valver up and have a listen for it.
Veedubgt18v
Guest
Re: fuel pump
Reply #7 on:
11 December 2004, 09:43 »
i can only hear mine when i start the car but only then for about 3 seconds
Gambit
Forum addict
Re: fuel pump
Reply #8 on:
13 December 2004, 09:17 »
the main pump on my old 16v was quiet as a mouse. my new one is really loud. the lift pump is something ill be changing v.soon in the hope of quietening down the main pump
Golf mk2
fuel pump
