Author Topic: K04-001 help  (Read 2249 times)
Offline big_vw_ash
K04-001 help
« on: 21 May 2010, 16:18 »
ive herd about this turbo through a friend but i wanted to double check with you guys, basicly wanna know if i buy this K04-001 will i need to do anything else mod wise for it to run right. i know if i want to get full potential out of it then i'd need 4 bar fpr, fmic, 007p, bigger fuel injecters and so on. but if the turbo went on with no other mods to start with (its a standard AGU) apart from TIP due to being bigger would it run ok and if i got it mapped would it see k03s figures?? im just asking as i want a bigger turbo but would rather shell out abit more for the k04-001 than the k03s as will give more power in the long run.
really apreciate any advise on this one.
heres a link for the turbo http://xs-power.com/turbos-10.htm
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: K04-001 help
« Reply #1 on: 21 May 2010, 16:39 »
First off, thats not a genuine turbo. You will want to get a Borg worner genuine turbo.
Ideally if you fit the turbo then you will want a map on your car for it to run right as its bigger than the stock item. Your better off get the turbo, FMIC, 007p, TIP, fpr, fuel pump and remap all done at the same time.
Offline linz
  • vee-dub
Re: K04-001 help
« Reply #2 on: 21 May 2010, 20:33 »
yes the k04 001 is a bolt on replacement but really it is just a k03s in a k04 shell..... imo its not a proper k04
an to what you want power wise would depend on what else you would need to buy!
ive just done a full proper k04 upgrade an i can tell u it has cost me a small fortune!
Offline brianpologti
Re: K04-001 help
« Reply #3 on: 22 May 2010, 16:37 »
Watch out there are a few that have the wrong size inlet, so the ko3 tip won't fit unless ur cut the end off and fit a new end etc , can't remeber the sizes but there's a thread on seatcupra.net
Offline Hulmie
Re: K04-001 help
« Reply #4 on: 22 May 2010, 17:07 »
easy you just buy the right TIP for the turbo or try get one that comes with the TIP
Offline big_vw_ash
Re: K04-001 help
« Reply #5 on: 23 May 2010, 10:26 »
do u mind me asking how much it cost u and who did the conversion?
Offline fowler21
  • veeeeedub
Re: K04-001 help
« Reply #6 on: 29 May 2010, 13:20 »
You might also need a bigger intercooler?? i herd ebays quite good ?
Offline linz
  • vee-dub
Re: K04-001 help
« Reply #7 on: 29 May 2010, 16:11 »
a garage near me did the conversion he does all sorts of modified car upgrades an in total with parts labour ect i was probably nearing the 3k mark.....
