Author Topic: Few Q's, just for clarification.  (Read 1490 times)
Offline maxp
  • J reg 8v digi gti
« on: 20 May 2010, 23:32 »
Just a few q's for clarification:
Did all mk5 gti's with multifunction steering wheels get highline computers as standard?
Has anyone actually got a quote from VW for retrofitting highline? All the info ive read seems all very contrasting.
Cheers  :smiley:
Offline Davstylee
Re: Few Q's, just for clarification.
« Reply #1 on: 21 May 2010, 06:30 »
I don't think they did mate. I have an 05 reg GTI with a multifunction steering wheel but no high line. They may have done it in new models mind???
I am also interested in getting the high line fitted and would like to know where to get it done and how much it would cost.
Mrk V, GTI, 3dr, DSG, heated seats, winter pack, cruise control, rear parking sensors and now thanks to GizzyWizzy and SteveP in the MK6 section a RCD 510. Awesome!
Offline stealthwolf
« Reply #2 on: 21 May 2010, 06:47 »
As above, the early models were quite wierd. You could buy DSG without the tiptronic controls, and you could buy MFSW without highline. I believe in later models, they were paired up.
As for highline, if you buy from dealers and have them code it (1 hour labour) you're looking at £400. Bear in mind it was an optional extra that would have cost £50!!! The unit brand new is expensive. You can have a look on ebay for second hand ones. Highline wasn't standard on the GTI/ED30 but was on the R32 (I believe).
If you buy a unit, dealer should be able to recode and fit for 1 hrs labour or so. Apparently others have had it done by Shark Performance. Either way to code it properly, including for mileage, means you need to have the correct equipment (apparently hooked up to germany!) so not many people can do this.
You should go for a unit that's compatible with your cae so ideally needs to come from the same year.
