Author Topic: Engine STOP light comes on for Oil Pressure Low ??  (Read 3022 times)
Offline HeidiG
When iam driving say around town nothing happens but when i go on a run say travelling down a duel carrageway the engine STOP flash`s up and says Oil Pressure Low
I have checked the oil level and it is ok
The oil i use is Fuchs 5/30 fully synthetic
Any Ideas would be great
Iam having a few problems with it at the moment
Offline Horney
Re: Engine STOP light comes on for Oil Pressure Low ??
« Reply #1 on: 19 May 2010, 16:30 »
Faulty sensor or you actually have low oil pressure. Get it checked before you wreck your engine.
nick
Offline Rhyso
« Reply #2 on: 19 May 2010, 16:49 »
Low oil pressure
Faulty sensor flashes up WORKSHOP (I know this as mine's up the swanny)
Most common cause is the strainer in the bottom of the sump.  You'll need to drain the oil and remove the sump to clean it all out
As Nick says get it checked out ASAP but avoid driving it unless its at a sedate pace on your way to a garage!  But ideally get it recovered
Offline HeidiG
« Reply #3 on: 19 May 2010, 17:32 »
Where will the oil pressure sensor be on a aum engine
will it be in the block ??
Any pics or any ideas on how much they are
Offline Horney
« Reply #4 on: 19 May 2010, 18:08 »
Rhyso has already told you above if it was the sensor it would flash up WORKSHOP. Therefore your car is likely running low oil pressure. You need to drop the sump off and clean out the strainer on the oil piump pick up pipe. DO not drive it till you have had this done or at least checked.
nick
Offline Rhyso
« Reply #5 on: 19 May 2010, 18:14 »
The pressure sensor itself is located on the block i believe  :undecided:
Sorry I was on about the oil level sensor  :embarassed:  that's in the bottom of the sump but if its faulty it would still flash up workshop
Either way get it checked out ASAP!! Low oil pressure = KABOOM and expensive rebuild  :sad:
Offline ggggolfgti
« Reply #6 on: 19 May 2010, 18:35 »
hi mate its an easy enough job to clean the sump, and a worth while one, ive had the dreaded sludge in the pick up and it can cause real damage if you dont get enough oil around the engine, do you use engine oil flush when changing the oil?
249 bypass, ths fr3 engine mounts, S/S decat, 2.5'' straight through exhaust, induction kit, forge split r, coilovers, 18'' alloys, much more in the pipeline
Offline HeidiG
« Reply #7 on: 19 May 2010, 19:13 »
I Missread about the sensor being faulty and it saying workshop
It doesnt say workshop so i will get someone to take the sump of and clean out
Thanks for the help
« Reply #8 on: 19 May 2010, 21:19 »
I would not use it until you get it checked.
Offline mike_j_b
« Reply #9 on: 20 May 2010, 10:28 »
quick note buy a new oil pickup pipe before attempting to clean the sump (£6 part from the stealers) when i did mine it was completely blocked with just a few pin sized holes remaining , saves spending a lot of time cleaning it out for a cheap part easy enough job to do off a pair of axel stands , ohh and gasket glue ftw to ensure no leaks :)
