Author Topic: 106 hp driver  (Read 3250 times)
Offline maximous
106 hp driver
« on: 08 December 2004, 16:35 »
Went to power engineering today with a few friends and took the mk2 driver, (the 16v isn?t ready yet) and to my surprise it came out with 106 hp and 109 lbs of torque, sorted.  :wink:
Offline topher
  • Administrator
  • fully functioning
Re: 106 hp driver
« Reply #1 on: 08 December 2004, 16:39 »
wait till Fielder gets hold of this :grin:
Any engine mods ?
Offline maximous
Re: 106 hp driver
« Reply #2 on: 08 December 2004, 17:04 »
a cheap set of high lift cams (kent) - cant remember the spec.
advanced timing.
no air filter.
second hand s/s bak box (?20).
good maintance.
Fielder5757
Re: 106 hp driver
« Reply #3 on: 08 December 2004, 18:04 »
 :shocked:
I know Rich got 90BHP using a cam and a new Carb, Woha!!
Whats advanced timing?
Offline maximous
Re: 106 hp driver
« Reply #4 on: 08 December 2004, 18:31 »
Advanced timing is when you change the timing of the spark pattern; you can do this on drivers by taking out the dizzy and rotating it to the correct degree. When the VWs come off the assembly line they are set to a ?safe? limit. I advanced the timing until it started ?pinking? then wound it back a bit until all was good. My description is a bit vague, you really need someone to show you how, but it?s quite simple.
The operator was really shocked and said if I put a full stainless system on it and tweaked the fueling a bit ill be very close to GTI standards
Veedubgt18v
Re: 106 hp driver
« Reply #5 on: 08 December 2004, 18:35 »
seriously? is that the 1.6 or 1.8? thats pretty good! go on rip the interior out of it bung a weber on and exhaust and TRACK CAR!!!
Offline maximous
Re: 106 hp driver
« Reply #6 on: 08 December 2004, 19:31 »
That would be the 1.6. :evil: Its the runn around until the 16v is finished. When im done it will be my track car on twin 40s(i think), the suspensions all done appart from the anti roll bars.
Veedubgt18v
Re: 106 hp driver
« Reply #7 on: 08 December 2004, 19:35 »
 that sohould be good, lightne it as much as you can, chop out boot floor etc should be good for a laugh!  :grin:
Fielder5757
Re: 106 hp driver
« Reply #8 on: 08 December 2004, 20:31 »
Mk2s are really easy to strip, So easy infact that my nabours 9 year old kid did mine for me with a screw driver, hammer and chizel  :shocked:
Offline Rhyso
Re: 106 hp driver
« Reply #9 on: 08 December 2004, 21:09 »
Any idea how much the cams cost?? Whats ur MPG like with that extra power??
