Author Topic: MMmmm floormounted pedal boxes  (Read 7419 times)
Offline Horney
« on: 18 May 2010, 21:48 »
http://www.compbrake.co.uk/PEDALBOXES/PEDALBOXES4.html
No reason other than they look sexy!
Nick
Offline johnson6672
Re: MMmmm floormounted pedal boxes
« Reply #1 on: 18 May 2010, 22:03 »
Thats not bad, means you can position your drivers seat further back if you extend the steering column, look how far back the seats are in a citroen c4 rally car.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 19 May 2010, 00:15 »
Jeezus, think about the number of other things you'd need to move backwards!
Horrendous and crazy idea IMO.
But I think Nick's just being a perv.
VeeDubGTI16v
« Reply #3 on: 19 May 2010, 09:02 »
exactly, touring cars have used this idea for years
Offline Horney
« Reply #4 on: 19 May 2010, 09:32 »
Indeed, you'd have to move all the switch gear, then the shifter housing (in my case change to cable as well). A lot of stuff to shift about.
I only found them through lookking for a bias valve. They do do bias peddle boxes that fit in the OE way as well.
nick
VeeDubGTI16v
« Reply #5 on: 19 May 2010, 09:46 »
but then you can have a cool switch panel on a bit of carbon fibre sheet  :laugh:
plus the weight savings by removing servo and oem pedal box from the drivers side of the car
plus moving the weight of the driver backwards
plus a nicer seating/pedal position
its definitely worth the effort
Offline johnson6672
« Reply #6 on: 19 May 2010, 10:48 »
Thatswhat i was thinking, get a ratchet shifter aswell :evil:
Offline fishnchipsx2
« Reply #7 on: 24 May 2010, 20:58 »
Something to save up for, for when I go 02a w/hydraulic clutch in the mk1  :tongue:
« Reply #8 on: 20 June 2010, 11:24 »
A word of warning - someone I know with one of these compbrake boxes in his mk2 vr broke it when braking hard from 100mph the other day.  :undecided: Apparently theres only a few spot-welds holding the box together.  :rolleyes:
So if you get one, beef up the welding before putting it in! (He has done this now and is very satisfied with it  :cool:)
VeeDubGTI16v
« Reply #9 on: 20 June 2010, 11:28 »
 :shocked:
i hope he informed compbrake
