Author Topic: MK1 CABRIOLET REAR BRAKE HELP  (Read 1906 times)
Offline fragilebartman
« on: 17 May 2010, 13:53 »
Hi does anyone know how to adjust the rear brakes please. Footbrake works fine. Handbrake is adjusted to the limit but for some reason the O/S wont work on handbrake although the N/S does.
Is there another way of adjusting ive taken drum off but cant see an adjuster
Thankyou
Offline raferackstraw
Re: MK1 CABRIOLET REAR BRAKE HELP
« Reply #1 on: 17 May 2010, 22:19 »
iirc depending on year they should be self adjusting, it maybe that your cables need replacing as there is no adjustment left. you may want to overhaul both rear brakes rather than trying to make do. altho 80% of braking is done by the fronts the rears have a large effect on pedal feel and overall performance
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
