Golf mk2
Water pump
Topic: Water pump (Read 3277 times)
Lee
GTI forum regular
Oiiii stop your dog sh!tting on my lawn
Water pump
07 August 2003, 11:55 »
Hello
My water pump makes a fun bearing type noise when the fan comes on then goes away once the fan cuts out. Is this going to be a crap job to replace or not, my car is a mk2 16v.
Ape shall never kill ape
richandhazel
Global Moderator
Forum addict
Re:Water pump
07 August 2003, 13:47 »
Hi Lee,
Don't understand why your water pump bearings should make a noise just because the fan comes on...........not being funny, but are you sure its not the fan itself? The fan bearings, can go.........I've had to replace one before now.
Lee
GTI forum regular
Re:Water pump
07 August 2003, 15:34 »
Hello rich its not the fan bearing, it comes from the water pump/cambelt/powersteering area. All the belts are tight aswell.
richandhazel
Global Moderator
Forum addict
Re:Water pump
07 August 2003, 17:16 »
It's not your alternator bearing is it? Maybe the alternator is getting loaded up when you're cooling fan comes on
Just out of interest how freely does the cooling fan rotate......maybe its seizing causing a higher load on the alternator???
Lee
GTI forum regular
Re:Water pump
07 August 2003, 21:50 »
I will take a look at the fan tomorow.
Lee
GTI forum regular
Re:Water pump
08 August 2003, 14:18 »
I was going to have a look today but its just to hot to be messing about under the bonnet. I will give it a look when its a little cooler cheers.
modulater
Re:Water pump
Reply #6 on:
11 August 2003, 23:52 »
I'd vote for the alternator bearings as well, maybe the belt is too tight and needs to be loosened slightly. Get a long screwdriver or ratchet extension and place it on the alternator when the engines running, put your ear to the end of the tool your using and if its bearings you'll hear them.
Lee
GTI forum regular
Re:Water pump
Reply #7 on:
12 August 2003, 12:28 »
Cheers i will give it a try later.
Golf mk2
Water pump
