Author Topic: Brake Dust!  (Read 3971 times)
Offline J4M3S
Brake Dust!
« on: 15 May 2010, 20:07 »
Hi guys, the wheels on my Gti are pretty filthy! Tried cleaning them with the usual chemicals but there are lots of black brake dust spots that just wont shift!! Any suggestions?  :smiley:
Offline dragonfly
Re: Brake Dust!
« Reply #1 on: 15 May 2010, 22:54 »
Have you tried Autosmart Tardis? Failing that clay them.
Offline Dan J
Re: Brake Dust!
« Reply #2 on: 15 May 2010, 23:50 »
the spots on your rims are a combination of tar/breakdust/grit.
as suggested above get some tardis or preptone which will remove the tar then clay afterwoulds to remove any inbedded contaminents then seal and wax them to protect them, this will reduce this from happening in the future if you keep ontop of them :wink:
« Last Edit: 15 May 2010, 23:53 by dubplate Dan »
Offline J4M3S
Re: Brake Dust!
« Reply #3 on: 16 May 2010, 09:09 »
thanks guys, will give it a go
Offline VWKev
  • Please Support Non-Human Rights
Re: Brake Dust!
« Reply #4 on: 17 May 2010, 12:39 »
I've jetsealed mine since new and my alloys hardly need washed, sometimes a rub down is all the need and the only thing thats needs cleaning is my tyres. I have had no dirt/tar etc on them that is not removed either by a quick wash or a wipe. I use 3 coats of jetseal now instead of 2, for no other reason than I want to.  :grin:
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline javalin
Re: Brake Dust!
« Reply #5 on: 17 May 2010, 14:28 »
yeah Jetseal is top stuff.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Chris MKV
Re: Brake Dust!
« Reply #6 on: 17 May 2010, 18:15 »
I've used autogymm wheel sealant and it has had the same effect most dirt just hoses off.  A light brush with shampoo and water then is all they need.
I'm sure the fancy sealants are even better but since the one I have is just a quick spray and wipe job it is just not worth not doing them.
I've been a target for 'halfords spec' saxos for almost three years now!
Offline VWKev
Re: Brake Dust!
« Reply #7 on: 18 May 2010, 12:55 »
I've not really has much to compare against when it comes to sealants, but I can say for sure the fancy (jetseal) just seems to last and last, I can get 2-3 months out of it before the alloys need touched again.
Offline Chris MKV
Re: Brake Dust!
« Reply #8 on: 18 May 2010, 18:04 »
How do you apply it (jetseal)?
Is it pretty easy like waxing the wheels or something more complicated?
Offline jeynesey
  • Non VW but still VAG
Re: Brake Dust!
« Reply #9 on: 18 May 2010, 21:33 »
Poorboys sealant smells ossum too  :grin: :grin:
