Author Topic: problem with central locking  (Read 1489 times)
Offline lfcscott
  • Mk3 gti 2.0 8v
« on: 13 May 2010, 07:47 »
hi everyone
                can anyone help plz?? ive pulled up on the drive this morning & went to lock the car up & noticed my central locking has stopped working,also my electric sunroof has packed up at the same time  :undecided: does anyone have any ideas???
Offline lfcscott
  • Mk3 gti 2.0 8v
Re: problem with central locking
« Reply #1 on: 13 May 2010, 08:18 »
also ive noticed the clock resets everytime i turn the car off & turn ignition back on??? anyone??? anyone??? :undecided:
« Reply #2 on: 13 May 2010, 09:02 »
Battery voltage dropped.
« Reply #3 on: 13 May 2010, 10:01 »
check zee fuses
Offline lfcscott
  • Mk3 gti 2.0 8v
« Reply #4 on: 13 May 2010, 17:06 »
checked the fuses all seems ok,i am wondering about the battery though :undecided:
Offline lfcscott
  • Mk3 gti 2.0 8v
« Reply #5 on: 14 May 2010, 08:53 »
would a drop in battery voltage just affect my central locking & elec sunroof & cigarette lighter?? :embarassed: as everything else seems to be ok for now,i have noticed that when i press the sunroof switch the illuminated light on the sunroof just goes out & you here a click.
« Reply #6 on: 14 May 2010, 10:02 »
does it do this with the engine running?
Offline lfcscott
  • Mk3 gti 2.0 8v
« Reply #7 on: 14 May 2010, 15:17 »
yes it does  :cry:
« Reply #8 on: 14 May 2010, 16:00 »
doubtfull a problem with voltage then, i take it the battery light comes on with ignition then goes out when car running?
id be looking at the earhts next, the cl motor has an earth point behind the passenger side doorcard.
fuse 21 does both the sunroof and the central locking though, so I'd take it out and check it with a multimeter. ive seen em go with a hairline crack thats difficult to spot
Offline lfcscott
  • Mk3 gti 2.0 8v
« Reply #9 on: 14 May 2010, 16:52 »
im a dollard  :embarassed: you are bang on rite it was a heirline crack in the fuse  :embarassed: thanks to evryone who help fantastic thanks again & especially you rub jonny :wink:
« Last Edit: 14 May 2010, 17:07 by lfcscott »
