Author Topic: PSI Presure on a gttdi 115  (Read 5795 times)
Offline EuanGtTdi
« on: 12 May 2010, 14:58 »
Just wondering if soemone could tell me what psi my boost gauge should read under full load on my gttdi 115?
as it hits 25psi and drops off a wee bit?
Euan
Offline Rhyso
Re: PSI Presure on a gttdi 115
« Reply #1 on: 12 May 2010, 15:03 »
standard or mapped??
25PSI peak sounds about right - you'll overboost then settle down
My 130 hits 27PSI then settles at 23PSI with the R-Tech spec 2 map
Offline EuanGtTdi
« Reply #2 on: 12 May 2010, 15:21 »
its supposidly got a chip on it  :undecided:
so im not sure as i kind of thot it was high for standard mate
Offline Rhyso
« Reply #3 on: 12 May 2010, 15:29 »
it won't make much more than that due to the size of the turbo
Not entirely sure what standard PSI they run at tbh; think the 130 is 23 to 19  :undecided:
What does it drop off to?  And does it keep dropping?
Offline EuanGtTdi
« Reply #4 on: 12 May 2010, 15:30 »
if i floor it, its pings to 25 and drops to about 20 and holds it mate
Offline Rhyso
« Reply #5 on: 12 May 2010, 15:46 »
The fact that it holds it means everythings working as it should!
Offline Adam
« Reply #6 on: 12 May 2010, 17:28 »
Wish mine did that :(
I peak at 26psi hold 23psi then tail off at 19psi with no visible signs of a boost leak. :(
Down Hill From Here.
Offline Steve_PD
« Reply #7 on: 12 May 2010, 17:52 »
mine hits 29psi and holds 24psi
Offline Adam
« Reply #8 on: 13 May 2010, 01:31 »
You do have the better turbo.
Offline asif
« Reply #9 on: 13 May 2010, 09:08 »
And a better map most probably.
MK7 GT Bluemotion Tech TDi 150
