Author Topic: 20vt mk2 sleeper project.written off :(  (Read 224520 times)
Offline lewis1641
  • stuck in the 90's
Re: 20vt sleeper project. ITS ALIVE!!!
« Reply #580 on: 11 January 2013, 11:55 »
I think the towers are the same. Are your cables mounted anywhere?
Had a text back from gareth at map-tech, he does immobiliser delete and stage 2 remap for 225 plus return post.
His number is 07837827499 www.map-tech.co.uk
Tell him Dave sent you.
Offline lewis1641
  • stuck in the 90's
« Reply #581 on: 29 May 2013, 15:07 »
Long overdue update.
not sure where we were but this is where we are
It is done bar uprating the master cylinder, sorting 2 wiring issues and sealing the exhaust.
Offline lewis1641
  • stuck in the 90's
« Reply #582 on: 29 May 2013, 15:17 »
the car has moved units and is at my mate's garage now.
It went there with a few niggles - gear cables needed sorting as missing bracket on box, header tank needed relocating, rad fan needed installing, steering joint was catching downpipe, fly by wire throttle pedal needed installing.
Really happy with the work that went into the rad fan. the original gti cowling has been sectioned to fit the 1.3 rad, then sliced to fit the fan.
downpipe has been cut and shut to clear the steering joint, mount made for the accellerator pedal, header tank bracket welded on the opposite side of the bay.
Sadly i had to sell the BBS RC splits to fund some other project so it is just sat on e46 15's at the minute awaiting something better.
Currently waiting on a few parts to arrive - exhaust gaskets, ibiza cupra master cylinder and the bracket for the gear cables.
Then we have 2 anomolies in the wiring to sort, full spanner check then mot and wheel alignment
Offline lewis1641
  • stuck in the 90's
Re: 20vt sleeper project. updated page 59
« Reply #583 on: 01 June 2013, 11:16 »
rant he car up to temp last night, sounds lovely now the exhaust is sealed but we have an issue. it sits beautifully at idle but floor the throttle and there is a delay before the revs pick up.  I am wondering if it is the fly by wire pedal at fault?
Offline lewis1641
  • stuck in the 90's
Re: 20vt mk2 sleeper project. updated page 59
« Reply #584 on: 15 June 2013, 14:54 »
sorted the fault, vac pipe missing off the fuel pressure regulator!
also sorted the ignition switch wiring but most of the rest of the wiring on the car needs attention, so that is being sorted now.
It was driven outside today for a bath
now cracking on with the wiring and refurbishing another set of bbs rc's for it.
Offline lewis1641
  • stuck in the 90's
« Reply #585 on: 29 January 2014, 13:11 »
UPDATE
the car has mot! so so happy
sadly it also isnt boosting so wired up an obd port and it looks like i need a boost pressure sensor, map sensor and maf sensor.
when will the spending stop!
« Last Edit: 29 January 2014, 13:16 by lewis1641 »
Offline lewis1641
  • stuck in the 90's
Re: 20vt mk2 sleeper project. updated page 59 MOT PASSED
« Reply #586 on: 30 January 2014, 10:50 »
Few more tinkering so last night. Did some reading up on speedo cables and ordered a mk2 1.3 cable.
Simply remove the sender from the box, screw in the cable and attach to the clocks. Took it for a spin and it works spot on.
Replaced the maf with a new one and it's running loads better. Attempted to replace the MAP sensor too, only to realise I don't have one installed lol. I guess there lies the boost issues.
I bought the intercooler and pipe work off an converted mk2 that was being broken, he was using aftermarket management so I guess didn't need the map sensor. My mate is off to the scrap yard today to try and get a housing so we can install it. Hopefully that will sort the issue as I am itching to get some miles in.
« Last Edit: 31 January 2014, 16:43 by lewis1641 »
Offline lewis1641
  • stuck in the 90's
« Reply #587 on: 31 January 2014, 16:45 »
MAP sensor in and no fault codes. yay
tonight we are adjusting the brake bias and tweaking the cable shift ready for taxing in the morning and getting some miles on it.
its off to www.map-tech.net sunday morning for a dyno run to see where things stand
Offline Mcwill
« Reply #588 on: 31 January 2014, 20:56 »
Hi bud your just round the corner from me, barton.
Hoping to get my car down to map tech at some point will be good to see ow you get on.
Rick
Offline lewis1641
  • stuck in the 90's
« Reply #589 on: 01 February 2014, 00:10 »
Hi rick, I have been happy with all their other work (e36 325 and mk4 1.8t ) so hoping for great results on this too.
What are you driving?
