Author Topic: 20vt mk2 sleeper project.written off :(  (Read 198660 times)
Offline lewis1641
  • stuck in the 90's
Re: 20vt sleeper project. ITS ALIVE!!!
« Reply #570 on: 11 December 2012, 08:52 »
Hi Corey. I am running the stock k jet gti pump, I have been told they are up to th job.
Wiring got a little confused as I think we made a mistake. We followed rubjonny's guide for splicing the looms. We needed to swap the fuel pump relay but I can't remember which one we used and I do.t know if this was needed to correct a orevious error so not much help.
Don't have a pic of the battery yet but all we did was turn it 90 degrees then slide it as far forward as possible so the front edge is under the slam panel and behind the headlight.
Offline Cory
« Reply #571 on: 11 December 2012, 22:58 »
ahh right. thats good im also using a k-jet pump. thought i got it all wired up today. sounded like it was priming, turned the key and it was cranking but no start up. wars gonna go through it all with a multi meter but got too dark. im using a 30A relay as per my friends mk1, so might be a little different to yours. do you have a link to rubjonnys guide? what problem did you have with yours?
 i tried the battery like you have but the clamps didnt reach the terminals. have you extended your battery wires at all?  im guessing the way you have it, that it still fits under the battery tray clamp (if that makes sense?) as mine did also.
thanks
Cory
Offline lewis1641
  • stuck in the 90's
« Reply #572 on: 11 December 2012, 23:25 »
It still fits in the standard clamp. As for the wires, I fitted a longer live to the starter motor. The others were ok, just needed to undo some cable ties to make a bit more slack.
I will try and find a link.
The only problems we had were not following the guide properly!
Offline Dave-iow
« Reply #573 on: 10 January 2013, 20:26 »
Can i ask how much your mate charged for the map and immo remove ?
Offline lewis1641
  • stuck in the 90's
« Reply #574 on: 10 January 2013, 21:21 »
He did It for free for me but I will get a price for you.
Are you running cable shift? If so I have questions!
Offline Dave-iow
« Reply #575 on: 11 January 2013, 06:12 »
Yes will be running cable shift with an 02j gearbox. If you can get a price that would be great.
Must get a build thread up as well
Offline Dave_IOW
« Reply #576 on: 11 January 2013, 10:57 »
I'm running cable sh!t with 02J also.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline lewis1641
  • stuck in the 90's
« Reply #577 on: 11 January 2013, 11:13 »
Aargh there are 2 of you lol!
Can either of you help with my shifter? I have the unit installed and cables attached to the o2a box but there is no tension. Won't select gears and shifter sloppy. I assume I need some cable stops somewhere so the inner cable moves and the outer doesn't (like a clutch cable)
What am I missing? I have literally got the cables attached at both ends and nothing more.
Offline Dave_IOW
« Reply #578 on: 11 January 2013, 11:20 »
Hmm, I'm using 02J shift tower and box, not sure how they differ?
Offline Dave-iow
« Reply #579 on: 11 January 2013, 11:27 »
Im using 02j shifter tower as well
