Author Topic: 20vt mk2 sleeper project.written off :(  (Read 201114 times)
Offline lemski
  • 16v
Re: project £500 rear suspension bodged!
« Reply #350 on: 27 November 2010, 15:23 »
I told you didn't I dave. Get some more 60mm rear springs mate. Dampers are fine I would think. Then see how it sits. And if its still lower on back save for coillies and as I would say slam it.
Offline SoundillusioN
« Reply #351 on: 29 November 2010, 12:18 »
Looks better now... what bodge did you end up doing?  can't seem to find where you said what you did?
Offline lewis1641
  • stuck in the 90's
« Reply #352 on: 29 November 2010, 13:18 »
ended up using the koni dampers with mk3 rear springs with one coil cut off!
dont know how it will handle as there's thick snow everywhere at the minute
Offline Peej1981
  • Its Whats Under The Hood That Counts........
« Reply #353 on: 29 November 2010, 15:57 »
Mr Lewis you are the biggest bodger so this does not supprise me  :laugh: :laugh:
www.bombercountydubs.co.uk
« Reply #354 on: 29 November 2010, 17:20 »
That shouldn't stop you trying... might be more fun!  :grin:
Offline tsr_adi
« Reply #355 on: 29 November 2010, 17:28 »
car park drifting FTW
Offline lemski
  • 16v
« Reply #356 on: 29 November 2010, 17:35 »
*Cough* coilies *cough*
Offline lewis1641
  • stuck in the 90's
« Reply #357 on: 29 November 2010, 19:36 »
Its not that much of a bodge kai- no zip ties, bunjie straps or rape tape used.
I did have a bit of a play in the snow but not enough to know if the back end will stick or not.
Coilies will be on hold till after christmas.
Offline lemski
  • 16v
« Reply #358 on: 29 November 2010, 19:51 »
Good plan that. So what made you cut a coil of mk3 springs and put them on the mk2 surely the sagged suspension would be better still. And did you get your new wheels on??
Offline lewis1641
  • stuck in the 90's
« Reply #359 on: 30 November 2010, 00:01 »
I used mk3 springs as i had them laying around, as you do (they do have their uses i guess) but they were way longer than the eibach springs - it would have sat really high at the rear.
Wheels are not with me yet. Hopefully by the end of the week. Starting to think about putting the twists back on with the rear 'sorted'. Less sag may mean no scrubbing. If that is the case i might have some cheap boxster wheels to sell!
