Author Topic: 20vt mk2 sleeper project.written off :(  (Read 200420 times)
Offline Peej1981
  • Its Whats Under The Hood That Counts........
Re: project £500 worries and more wheels p22
« Reply #260 on: 15 November 2010, 21:39 »
Well the suspension you have now is out of the track isnt it? When i was driving the track i though it was incredible handling, dont think i have been in much that has been able to stick to the road like it did  :grin: Not been in yours yet, can i have a go??? You know i will let you have a play in mine. :smiley:
www.bombercountydubs.co.uk
Offline lewis1641
  • stuck in the 90's
« Reply #261 on: 15 November 2010, 22:19 »
You are welcome to a drive bud
Offline lemski
  • 16v
« Reply #262 on: 16 November 2010, 06:45 »
Get your cam reprofiled then. That's what mines had makes the lobes have a bit of a slope so the valves stay open longer and don't close as sharp. And okay I'll drive your car and have a see. Then I'll go with the verdict. :)
Offline lewis1641
  • stuck in the 90's
« Reply #263 on: 16 November 2010, 11:24 »
Feel free to have a drive.  I don't think it'll be as fun as yours.
How do i know what spec to have the cam cut to? Who would do it?
Offline lemski
  • 16v
« Reply #264 on: 16 November 2010, 12:50 »
I'll let youy drive neg then you can also compare and I'm not sure who can but less than mine as it ticks over at 1600 rpm just to keep it going. If you only have them cut 3 degrees each side the lobe will be nicly shaped but I as I said I don't know who could do it for you round these parts. Scott might know some one
Offline lewis1641
  • stuck in the 90's
« Reply #265 on: 16 November 2010, 13:40 »
the guy who wants to do my headwork did his own cam in his motorbike. he says it took him about 8 hours on one lobe. then you have to get them rehardened apparently.
Offline Peej1981
« Reply #266 on: 16 November 2010, 13:44 »
What about that place next to Julians, think it is called Collinwoods, they do head skimming and all sorts of machine work like that. Remeber from when i did that blokes alloys who worked there telling me they do all that sort of stuff. Maybe worth popping in sometime?
Offline lemski
  • 16v
« Reply #267 on: 16 November 2010, 16:54 »
Umm well u have the cam sat there you could see if he could do it and then take it to were he got it hardened
Offline SoundillusioN
« Reply #268 on: 17 November 2010, 10:05 »
been away, just doing some catching up!... bike carbs sound good but like you say i think it will drink!?...  not sure how often they need playing with though once setup... one of my fears of carbs, a bit fiddly...
Offline lewis1641
  • stuck in the 90's
« Reply #269 on: 17 November 2010, 23:57 »
Yeah i think i'm going to stick to injection.
Just had a few hours on the golf. Finally bolted up the front spoiler in the corners and replaced the thermostat- heat, yay! Planned to do a bit more but project neg got in the way....
