Author Topic: rear wiper stopped working.....any ideas?  (Read 6530 times)
Offline gti jimmy
« on: 11 May 2010, 22:42 »
hi all, my rear wiper has stopped working, checked fuse found to be ok. bought a cheap second hand wiper motor off ebay thinking it must be that but still no good! grrr! any ideas guys? and as for getting that rear panel off, thought i was going to rip the tail gate in 2!!!
jim :sad:
Offline jeynesey
  • Non VW but still VAG
Re: rear wiper stopped working.....any ideas?
« Reply #1 on: 11 May 2010, 23:00 »
Does it sound like the motor is trying to work?
Offline gti jimmy
« Reply #2 on: 11 May 2010, 23:39 »
no no sound at all :sad:
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 12 May 2010, 09:58 »
Fuse ?
There was a common fault with the MK5s where the wiper had a mind of its own. The fix was to replace the rear motor which implies its quite tempramental. If the fuse is all OK I would replace the motor.
If your car is still in waranty VW will do it for free.
Offline tuscan_thunder
« Reply #4 on: 12 May 2010, 11:59 »
Mine did this the other week after I washed it.
Before I got round to checking the fuse it started working again.
They might be prone to water ingress?
Offline wuker
« Reply #5 on: 12 May 2010, 16:20 »
Could this be a sensor issue like there is with the front wipers when the bonnet is open?
Worth a try
Offline crimsonfin
« Reply #6 on: 12 May 2010, 21:12 »
i had to take mine back under warranty as the wiper would intermittently stop working - would work fine then would stop working for entire days at a time.  dealer said it was a known motor fault
Offline gti jimmy
« Reply #7 on: 12 May 2010, 23:18 »
thanks for all your replies guy! i have tried another motor but still dead as a doe doe! looks like i will have to get the local dealer to have a look at it! ouuuuch!!!! ive also knackered the tailgate inner panel putting on and taking off! damn those clips are a pain in the a***!! :angry:
Offline Golfgirl
« Reply #8 on: 13 May 2010, 22:25 »
I thought mine had stopped working once but it turned out that the tailgate wasn't shut properly.
Offline gti jimmy
« Reply #9 on: 13 May 2010, 22:27 »
tailgate is slammed home but are there any sensors?
jim
