Author Topic: lacquer/clear coating help please!  (Read 2546 times)
Offline wakeboarder15
« on: 08 May 2010, 22:35 »
hi guys
recently smoothed and resprayed my bumpers :cool:
however after using the halfords custom paint mix spray cans and then lots of 'clear coat' ....about 5 coats they just dont have that 'gloss' to them that the rest of the car does!
so any ideas how i can achieve that same deep gloss...apart from getting it professionally done!
cheers
elliot
Offline LITTLEGADGI
Re: lacquer/clear coating help please!
« Reply #1 on: 08 May 2010, 22:51 »
have u wet flatted n buffed it up
« Reply #2 on: 08 May 2010, 23:00 »
whats wet flatted?
and no not buffed it yet...was seeing what people thoughts were!
cheers
elliot
Offline LITTLEGADGI
« Reply #3 on: 09 May 2010, 11:33 »
2000 grade wet n dry to remove any imperfections then buff up
« Reply #4 on: 09 May 2010, 14:01 »
ok thanks
do i use the 2000 on the lacquer?
cheers
elliot
Offline dom
  • Back in a Mk4
« Reply #5 on: 09 May 2010, 22:32 »
I recently had the same problem when respraying some of my bodywork. I left it a week for the lacquer to harden and then used a couple of different cutting compounds on it as well as a lot of elbow grease. The end result was really good.
It's a lot easier if you can get your hands on a machine polisher, but with a bit of patience and effort you'll get the finish you want  :cool:
« Reply #6 on: 10 May 2010, 14:09 »
thanks for the info ;)
only problem is i dont have a machine polisher...or have access to one :sad:
any other ideas?
cheers
elliot
Offline Birksy
« Reply #7 on: 12 June 2010, 23:36 »
any other ideas?
cheers
elliot
Elbow grease will do it. But it will take a lot of time and effort.
It's been a long time since I rock and rolled
Offline mike-a
« Reply #8 on: 13 June 2010, 22:34 »
Sounds like you've plenty of laquer on so let it harden and then wet flat it by hand.At first you'll see dull spots on a fairly shiny back ground.Keep going,gently,till it's all dull then polish it up.I just used T Cut and I was really happy with the match (did a pair of bumpers)
« Reply #9 on: 13 June 2010, 23:04 »
thanks for the info guys
i will try it out soon :wink:
