Author Topic: Loss of MPG  (Read 3240 times)
Offline Neildvs
Loss of MPG
« on: 08 May 2010, 10:19 »
Hi guys!! I was hoping to pick your brains...
I have the 130 gttdi with 104k on the clock. The MPG on motorway was only 48-52 which I thought was poor so I decided to clean egr and inlet manifold both were v coked in crap.. Since the clean my MPG has dropped to 43-48... Still doing around 500+ on afull tank
Does anyone have any suggestions on what's happened or on what needs to be done.
Any help would be much appreciated
Offline asif
Re: Loss of MPG
« Reply #1 on: 08 May 2010, 10:41 »
Don't count this as gospel but you may have pushed/moved some of that gunk down the exhaust manifold depending on how you cleaned it.
Other than that, when you put it back on it may be a little loose giving you a tiny boos leak.
500 miles to a tank is better than what I get, I only get 430 :( though I can't find my problem and haven;t had the EGR cleaned or deleted.
MK7 GT Bluemotion Tech TDi 150
Offline Neildvs
Re: Loss of MPG
« Reply #2 on: 08 May 2010, 10:47 »
Cheers for that bud I'll double check all the bolts are tight, they are a bugger to get too...
If I did accidently push some crap down the exhaust port how do I clean that out??
Offline asif
Re: Loss of MPG
« Reply #3 on: 08 May 2010, 12:13 »
The other part you wanna look at for leaks is the pipe that goes onto the EGR, very often that comes loose as the clips from VW are sh*te and the lugs can get worn giving you small leaks.
Not sure about the cleaning bit and don't want to advise you wrongly so will let a more experienced member give you some better advice.
Hope it gets sorted for ya and keep us posted.
