Author Topic: alloy wheel sizes ?  (Read 2152 times)
Offline graham
alloy wheel sizes ?
« on: 04 December 2004, 11:58 »
I have a mk 4 GTi 1.8 non turbo model fitted with 15inch alloys. What size can I safely go to, what are the poblems with different sizes, is it best to stay with the 15 inch? any advice or comments on tyres and wheels for this model.     Graham
Offline richy
  • neeeeeeeowm
Re: alloy wheel sizes ?
« Reply #1 on: 05 December 2004, 10:56 »
I've got exactly the same model as you.? ?:cool:
You can change the wheels to any size you like as long as the total radius remains the same (i.e. reduce the tyre profile accordingly).? I assume you've currently got 195/65/15s, as that's what my car came with.? You can change to 205/55/16s, 225/45/17s or 225/40/18s, as these all have almost exactly the same total radius to within a mm or so.
Just in case you didn't know, the x/y/z numbers mean the following:
x=tyre width in mm
y=tyre profile as a % of x
z=rim diameter.
The only thing to watch out for is the bolt arrangement, and offset.? You need 5x100mm, but I'm not sure about the offset (30mm?)
I've currently got some audi TT 17" alloys that I bought off ebay? :smiley:
« Last Edit: 05 December 2004, 19:49 by richy »
54-plate Golf 2.0 FSI GT.  Leather interior.
Offline frosticles
« Reply #2 on: 05 December 2004, 17:23 »
RS4's in 18's do look very nice but are a bit common. Have them on mine and don't care if there are loads around. Could put 18" BBS RC's as fitted to the Anniversary which are the dogs.
1978 Ford Escort MK2 RS Mexico, GTiTDiPD150. RS2's,Cruise,Metallic Black, Upsolute re-map. Goes and smells like stink.
Offline Pot-Gti-T
« Reply #3 on: 31 December 2004, 10:30 »
   Managed to fit 265/30/19s on mine, its lowerd 45mm and even with 4 passangers in it has never rubbed, even get full lock.
20 valves, a blower, Jetex induction, Remus full system, 19" RVRs
Offline R32_T
« Reply #4 on: 31 December 2004, 14:36 »
? ?Managed to fit 265/30/19s on mine, its lowerd 45mm and even with 4 passangers in it has never rubbed, even get full lock.
How the fcuk did you get 265 rubber to fit on the front??? EXPLAIN   :huh:
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
Offline Pot-Gti-T
« Reply #5 on: 31 December 2004, 15:02 »
? ? Sorry guys just been out to check, the rear tyres are 265/30/19 but the front are 235/35/19. Sorry again.............
« Last Edit: 31 December 2004, 15:05 by Pot-Gti-T »
Offline R32_T
« Reply #6 on: 01 January 2005, 12:58 »
Thought so...  :grin:
