Author Topic: Always starts from cold on 3 cylinders?  (Read 2488 times)
Offline jezza16v
« on: 06 May 2010, 20:03 »
Hi all, 89 small bumber 8v digi, 170k. When starting up from cold it always runs on 3 cylinders for a few moments then catches on the 4th. Its No1 cylinder thats not firing straight off, I replaced the plugs a couple of months ago which seemed to cure it for a short while, but the problem came back again, I replaced the rotor arm, dizzy cap and leads today but it fired up on three just the same and then settled down just fine. I took the plugs out again and No1 was very dry and tight to get out, the others had slightly oily threads and came out really easily. I've checked the coolant, it seems fine and clean, no mayo in the oil etc. no white smoke, nothing to suggest a HG problem, in fact it ticks over smoothly and runs very well. Just wondering if it could be a sticky injector, if there is such a thing?
Any ideas as to the cause of this problem would be very welcome.  :undecided: (BTW tried a search but nothing quite like this)
Offline Diamond Hell
  • Opinions я Us
Re: Always starts from cold on 3 cylinders?
« Reply #1 on: 06 May 2010, 22:46 »
At 170k your injector flow rates are likely to be all over the shop and I suspect the injector on No.1 is a bit slow to wake up, which is what's causing your initial poor running.
Fit new injectors and while you're at it, check the wiring is sound.
Offline jezza16v
« Reply #2 on: 07 May 2010, 09:18 »
Thanks, I've never had injectors out, is it a difficult job?
  • Opinions я Us
« Reply #3 on: 07 May 2010, 16:13 »
No.
Offline danj3000
« Reply #4 on: 08 May 2010, 17:15 »
I had a similar issue and it happened to be one of the valve seats that had become dislodged and thus stuck open. The problem started off rather sporadically but got continually worse, to the point that it wouldn't start at all. My engine was on around 175k when I developed the problem, so chances are it could be something similar for you. I also went down the route of thinking it was the injectors at first, only way to make out for sure is to take a closer look in the head.
Offline 6foot6
« Reply #5 on: 09 May 2010, 13:48 »
compression check the engine with the throttle wide open -  no more than 3 bar differance between cylinders , if no 1 is way down then then Rings could need replacing, once it warms up the rings expand and compression comes up and it starts firing.
Golf GTi 8v Alpine white - Project track shlag - TLC needed - KnN/Scorpien full system oval tail pipe, rust here and there.
1991 Toyota MR2 MK Revision 1 Turbo, rev 3 LSD, CT20b Turbo, HKS Exhaust, Blitz Downpipe 244HP@the wheels @ 13psi - 12.9 SQM :D
1994 BMW 730 V8 fully loaded 220BHP
Offline jezza16v
« Reply #6 on: 09 May 2010, 16:54 »
We replaced No 1 plug 'again' and it seems fine now, the last plug only went 2k, will have to keep an eye on it to make sure there is nothing causing it to eat plugs  :undecided:
Offline Brayster
« Reply #7 on: 09 May 2010, 19:13 »
I have the same problem with my 1.6 driver - hope u find the solution
Offline walchy01
« Reply #8 on: 10 May 2010, 18:17 »
Hi
I have this on my 16v, also plug 1, I did rocker cover gasket thinking somewhere inside was spilling oil into the plug, may I add it ain't solved the issue, keep at it can't be that hard to sort, :cry: can it
Offline jezza16v
« Reply #9 on: 13 May 2010, 09:01 »
Well, the new plug lasted for 6 days and now we're back to the same problem. Reluctant to change the plug again as it only misses for about 10sec on startup. Will keep scratching our heads and see what we can come up with, perhaps check out the injector next. Any other ideas most welcome.
